brake swap question
Old Apr 27, 2004 | 10:19 AM
vizsual00's Avatar
Default brake swap question
i have a set of gsr brakes that i'm putting on my 93 coupe. i don't have the e brake calble for the driverside and the brake lines were cut on both disk when the were taking out. are any of these parts hard to find and/or expensive to get. i 'm in the middle of the swap so i need them fast.
also is there way i can use my existing cables and lines
Old Apr 27, 2004 | 11:14 AM
b18bcivic's Avatar
Default Re: brake swap question (vizsual00)
get ss lines or goto auto zone for them,as for the cable i'm pretty sure u need the gsr one
Old Apr 27, 2004 | 11:22 AM
dantastic's Avatar
Default Re: brake swap question (b18bcivic)
you can use the parking brake cable off any 94-00 integra 3dr, or 92-00 civic coupe with rear discs
Old Apr 27, 2004 | 11:38 AM
vizsual00's Avatar
Default Re: brake swap question (dantastic)
it looks like i will have to go to the junk yard then. and is there a write up on chaning out the rotors on here. i found one that had the complete swap that is very informative and is helping me out alot but i just need one on how to change out the rotors since i got the peices out now
Old Apr 28, 2004 | 06:02 AM
vizsual00's Avatar
to top for more info
Old Apr 28, 2004 | 06:05 AM
Mike_C's Avatar
autozone has all the parts you need. the brake lines should be in stock, but i had to order my e-brake cables.
you can use stuff from 94-00 tegs or 92-00 civics with rear discs, it's all the same.
Old Apr 28, 2004 | 01:27 PM
vizsual00's Avatar
ok i ordered new brake hoses and e brake cable so that covers me there but now i have a new prob. i stripped the bolts where the shocks meet the lower control are and it seemed like it would be a pain to get the bolt out so i just bought 2 used lower control arms(wich i think i got raped on at $50 a piece). my question is could i just replace the bolts with some 14mm ones from homedepot or some other parts store. By the way if anyone wants to know why i am doing this is because i'm putting in shocks and springs at the same time as the brake swap. thanks in advance
Old Apr 29, 2004 | 11:32 AM
vizsual00's Avatar
ttt
mhi
Suspension & Brakes
Jun 30, 2012 11:16 PM
jdp1978
Nov 14, 2009 07:51 PM
N1ghtM0nkey
Mar 22, 2005 12:06 AM
BeavisB16
Jun 18, 2004 09:35 AM
