Question on block gaurds
Old Apr 27, 2004 | 08:05 AM
VTECisSeXY's Avatar
*insert here*
Default Question on block gaurds
Silly question maybe. But what exactally does a block gaurd do? thanks!
yes i have searched
Old Apr 27, 2004 | 12:18 PM
VTEC976's Avatar
Default Re: Question on block gaurds (VTECisSeXY)
Someone can correct me if I am a bit off, but a blockguard helps secure the cylander walls in place under higher RPM's. Honda uses a "floating" cylander wall to increase the amount of heat the head can dispurse and help in the overall cooling and efficiency of the engine. Thus, helping to make more power and keep temps down.
Old Apr 27, 2004 | 02:17 PM
Chiovnidca's Avatar
Default Re: Question on block gaurds (VTEC976)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC976 &raquo;</TD></TR><TR><TD CLASS="quote">Someone can correct me if I am a bit off, but a blockguard helps secure the cylander walls in place under higher RPM's. Honda uses a "floating" cylander wall to increase the amount of heat the head can dispurse and help in the overall cooling and efficiency of the engine. Thus, helping to make more power and keep temps down. </TD></TR></TABLE>
I think it helps keep manufacturing costs down also.
Old Apr 29, 2004 | 10:03 AM
tgreaves's Avatar
I have heard that it also restricts coolant flow.. But I dont use them I just pin the block and be done with it..
Old May 4, 2004 | 01:18 PM
boosted1993's Avatar
Default Re: Question on block gaurds (tgreaves)
vtec976 is correct................
cjmurillo
Dec 27, 2008 07:17 AM
team1320 B20eg
35
Sep 7, 2007 09:24 PM
kixcrx
Sep 5, 2007 09:52 AM
Scott (T.O.A)
Jun 12, 2005 03:14 AM
ChinitodeNJ
Jan 2, 2005 07:05 PM
