how fast is 220whp in 1/4 mile?..
i have a dx hatch weighing in at 2250lbs...and i have dyno my car at 220 whp...im planning on running it this weekend...what times should i expect?...with bfg goodrich drags radicals...mid 12's?...thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatch »</TD></TR><TR><TD CLASS="quote">Maybe low to mid 13's. </TD></TR></TABLE>
You could run a 12 second pass. Its definately not out of the question, even with the drag radials. But seeing that you have no seat time. Im gonna guess mid 13's at best. Unless your lucky enough to be consistent and pull good 60 fts on your first day at the track.
good luck.
good luck.
tom(b18c5-eh2) ran a 13.3 in his cx with pretty much a stock b18c5 and slicks. he said he could have pulled a 12.9 on another run if he had a better launch and his shifter fork hadn't broke on him. I would think anywhere in the 180-200whp range should get mid 13's or faster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS »</TD></TR><TR><TD CLASS="quote">13.5-12.9 depending on your driving </TD></TR></TABLE>
all depends on your driving
its posiible but i ran a 13.6 on drag radial my car is an integra realistic border 13.0 to 21.80-90's put slicks it'll run a 12.0-12.40 depend on your torque too
read this.... https://honda-tech.com/zerothread?id=746126
stop this BS thread, and make something useful out of yourself
b18c1 resleeved by rs machines...86mm..11.5.1 compressiom..3 angle valve job by port flow..skunk 2 stage 1 cams...hondata s100...
You guys are all INSANE...
I ran 12.80's @ 106mph in a 2200lb Civic Coupe N/A with *30* less horsepower to the wheels.
With 220whp and that weight, the car should do 12.30's
My friends car made 207 hp 143 tq weigh 2000lbs and ran 12.2 on 22x9x13 sliccs wit a peg leg tranny. Another friend made 211 hp 142 tq weighed 2279 ran 12.6 on 22x8x13 sliccs. So go with the 22x9x13 cuz of your tq and youll hit 12.2 wit a good driver.
Fresno_NSX
Apr 20, 2005 08:06 PM
Fab-Works
17
Jan 25, 2004 03:12 PM
