Build Or Replace
I recently started a hatchback project that will be turbocharged. I actually have not purchased the car yet but the ones I am looking at have 100k+ on the odometer, so I dont expected to last too long boosted. I would like to end up with 250whp.
Here is the turbo setup-
14b turbo
HF manifold
BMC Racing adapter plate
Stealthmode oil lines
TurboXS Type H BOV
DSM 450's
VAFC
Clutch (unsure)
Walboro fuel pump
If I was to build it I would just stick with rods and pistons with OEM bearings and gaskets. I want to retain a very reliable setup in the end so I would keep the boost pretty low, and keep it simple.
Importparts has Eagle connecting rods for 329, and I would have to find some pistons that would work well.
As far as price, Im still very well under budget for the entire car and build, so I can afford them.
So thats pretty much the plan, Ive never worked with internals before so Im new to this, please give me your opinions.
14b turbo
HF manifold
TurboXS Type H BOV
DSM 450's
VAFC
Clutch (unsure)
Walboro fuel pump
From: spinning DnB till your head explodes,jersey/philly
if u have a built block and good tuning i think u could pull 250whp. most guys that do a greddy turbo kit on a d series motor dyno at 175-200 horsepower range. if ur motor is built than u can up the boost a lil higher and ur set.
Yeah im with crx_88_si i dont think the 14b will be able to create enough power for 250 maybe 220 230 ( thats the best ive seen from homde made kits ) but then again i may be wrong.
but anyway if your building it then the mileage doesnt really matter much as long as you dont half *** the job. and if your wanting tot ap out the 14b your going to need a GOOD intercooler or you wont be able to safely boost any higher then 8 lbs.
and probably an after market fuel pressure regualtor and if you plan on running high boost you might want a better turbo (the 14b is inefective after 14 lbs ) something like a rhb5 or a t3/t4 hybrid those will run you quite a bit but there reliable. no sense in building an engine up just to slap on a underperforming turbo system ( not to rag on the 14b its a fine turbo for low to mid boost application).
just my two cents
although i seriously think you should consider a b series or h series if you want to make that much power .
just my two cents
The Ricer
Jan 4, 2006 11:16 AM
