1985 Civic VSS wiring problem.
Hi,
Hope someone can help. A freind of mine has fitted a B20 VTEC into his 1985 civic. It runs and pulls well with plenty of torque but can't activate VTEC. All the wiring to a ECU from a european spec 1991 B16a civic is done, except this.
His chassis does not have a Vehicle Speed Sensor that is needed for Vtec to activate.
Does anyone know a way around this, or a fix using a resistor or something, he really don't want to have to wire the vtec to a switch.
Anyhelp greatfully received
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slamdunkcivic »</TD></TR><TR><TD CLASS="quote">Hw is using the original that came with the 85 1.5 injection chassis.
Does he need a 88-91 cluster?</TD></TR></TABLE>
more than likely, I don't see how to get around it without using a cluster that gives a vss signal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slamdunkcivic »</TD></TR><TR><TD CLASS="quote">So will the 91 cluster fit from a Ef civic?
Will it drop straight in? Or will he have to start chopping the cluster wiring around as well?</TD></TR></TABLE>
pretty some modding to fit it and modding the wiring. never heard of it being done.
anyone else help out?
Hey mang tell your freind to go to http://www.redpepperracing.com
there you can learn how to wire the VSS from an 84- 87 crx hf in the the stock cluster.
your friend DOES not need to try to wire in a cluster that most likely never work, you just need to mod the one he has.
Lazysk8r2
Feb 19, 2012 06:51 AM
afterdark
13
Apr 30, 2009 10:12 AM
