just had an accident, pls help
I was trying to avoid a car infront of me that suddenly stop, I went up to the curb, now my bumper is scratch a bit, what else should I be worry and to look for to fix?? I know my alignment is off forsure, but what else could be wrong? I just want to know some possiblites before I take it to the shop tomr.....something like A arm or whatever that could be wrong? Both of my wheels went up the curb...Thanx ppl
-look to see if the shock is leaking fluid
-inspect the suspension bushings for failure
-check wheel for a bent lip
-check tire for sidewall failure
Will
Will
i wonder if some of suspension could have been bent when i slid into a curb last winter at like 20mph or so. The hub ended up going bad a month or so after and my car has been driving like **** ever since. Always some kind've a shake in the front end. Would you guys recommend a shop looking at the same kind've things? bent suspension? B.c my front end just shakes back and fourth as soon as the car starts to move. This is driving me crazy, I hate my car now
So I went home, take off the two front tires, exam inside the tire well on both side, everything looks ok, no leaks from shocks, nothing looks bent. I also examine the rim to see if it might be be bent, doesn't look like it except the cometic scratch on one of the rim which obsorb the impact. Afterward, I put my rims back on, and my alignment got a little better, but still off.
I'm going this weekend to get a alignment and my all my wheels rebalance.
just got back from the shop, I found out that my header got bend~! FXXX
my alignment is off, bumper and side panel is scratch up and crack. Other then that, everything else seems ok......rims didn't bend, control arm is good..suspension is good.
When I curbed my R and did $3,500 in damage I made an insurance claim (tip: don't call your insurance and tell them that you're "thinking of making a claim and just want to find out what it would do to your rates" -- they will file it as a claim anyway)... anyway, a year later when my policy renewed, it went down from 194/mo to 119/mo!! Progressive rocks!
Yeah, progressive insurance is pretty good. Also, you might want to check and make sure your fender still lines up with your hood. I ran over a curb, and after that, the fender was about 1.5mm higher, sux
ocular
Suspension & Brakes
Nov 27, 2007 10:12 PM
Homesickelian
Mar 5, 2007 04:06 AM
