EK armrest rear bracket
Hello. I have a 1998 civic hatchback. I put a 96 civic coupe armrest in this pass weekend but the back of the armrest is loose. Is there a rear bracket for this and if there is can someone get me the part # for it? Thanks.
Can someone find out the part # for the bracket in this? http://www.handa-accessories.c...t.pdf.
just print out that picture of the bracket and go to your local honda dealership. Tell them to order that if you they don't have it in stock, and if they order the wrong thing then just return it. Something so cheap wouldn't benefit you by buying it online. I would imagine that it would be terribly expensive but then again it is a "stealership"
bringing it back from the deal. For the back of the armrest, is Part #24 the correct rear bracket so the armrest is tight and not loose? just want to make sure before i put in a order. Part #24 under http://www.hondaautomotiveparts.com? thanks
