vtec is not working
Old Apr 26, 2004 | 09:53 PM
sihatch19's Avatar
Default vtec is not working
I have 97 jdm gsr in a 98 ls. every thing has worked until i gave up my conversion harness i ran an obd2 ls ecu an a obd2 gsr ecu for about a month both ecus were throwing second o2. The gsr recently started trowing vtec solenoid. Today my friend gave me a 97 jdm p73 ecu. the only code it throws is vtec solenoid. I rechecked all my wiring and it is all correct. I also changed the solenoid. and still no vtec. Any help would be appreciated.
Old Apr 26, 2004 | 10:01 PM
sihatch19's Avatar
Default Re: vtec is not working (sihatch19)
The code throws when i rev up to where vtec should kick. the tach also goes a little crazy.after about 6000 And bounces at like 6500.
Old Apr 27, 2004 | 02:29 AM
POWERLINEDOHCtor's Avatar
check your wire from the distrubutor to the tach, you may have a loose wire there. check to see if you are getting continuity from the solenoid to the ecu. and that pin A8 gets the vtec wire
Ryan Arnold
May 7, 2016 05:54 PM
acura00
Jun 5, 2007 07:00 AM
Gunns
13
Jun 1, 2004 11:15 PM
sk8phaze
Jul 28, 2003 07:44 PM
prjctCIVIC
Jul 7, 2001 09:50 PM
