would this header fit on a DX......
Old Apr 26, 2004 | 07:04 PM
sleepyhamsterlx's Avatar
Default would this header fit on a DX......
I know its' ebay ****, but it has a 2.5' collector.
Anyways as you see it has a plug on one of the runners. Is that for a 2nd o2 sensor. If it does fit my civic (SIG) then where is the brackets to support the header so it won't rattle. http://cgi.ebay.com/ws/ebayISA...78492
Old Apr 26, 2004 | 08:18 PM
Default Re: would this header fit on a DX...... (sleepyhamsterlx)
come on anybody
Old Apr 26, 2004 | 08:26 PM
Sasebonian's Avatar
You will have to setup a new catalytic converter since you have a 98 LX. Also from the picture, there are no brackets other than the ones used to mount to the cat and head. That is something you will have to live with if you get it.
Old Apr 26, 2004 | 08:58 PM
Default Re: would this header fit on a DX...... (Sasebonian)
but that plug on the runner is for a second 02 sensor correct
Old Apr 27, 2004 | 12:30 PM
up
Old Apr 27, 2004 | 12:39 PM
fivespeedcivic96's Avatar
nope wont fit
Old Apr 27, 2004 | 12:41 PM
Default Re: would this header fit on a DX...... (fivespeedcivic96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fivespeedcivic96 &raquo;</TD></TR><TR><TD CLASS="quote">nope wont fit</TD></TR></TABLE>
you sure, just cause it says for an EX, doesn't mean it wont' fit. to rephrase the thread, is that a second 02 sensor on the runner. and can i use both 02 sensors on the header then just use a test pipe afterwards, or do i need one of the 02 sensors in a Cat. converter
Old Apr 27, 2004 | 01:18 PM
can anyone give any info
Old Apr 27, 2004 | 01:30 PM
pornstarSR's Avatar
it will fit....
i ran a ex header on my DX...
but i did have to install a new cat underneath..
as far as that bung/bolt in the runner..
not 02 sensor.... it would only read 1 cylinder... NO GOOD....
you have to extend the primary 02 sensor wires to fit on the bung by the collector....and then either hang the secondary somewhere... or get a cat..
Old Apr 27, 2004 | 01:33 PM
Default Re: would this header fit on a DX...... (pornstarSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pornstarSR &raquo;</TD></TR><TR><TD CLASS="quote">it will fit....
you have to extend the primary 02 sensor wires to fit on the bung by the collector....and then either hang the secondary somewhere... or get a cat..</TD></TR></TABLE>
thanks for the info
STi-Thrill
Mar 29, 2010 05:55 PM
CereaLand
Jun 22, 2003 11:53 AM
sshaikh01
Mar 12, 2002 05:17 PM
TurbothisLS
Feb 19, 2002 05:44 PM
hondachick81
Jun 26, 2001 12:12 PM
