Transmission clicks in reverse
When its cold, my transmission clicks when I'm backing up. The clicking is exactly in time with how fast I'm going, the faster I go the fast the clicking becomes. Has this happened to anyone else? Is something broken or about to break?
shouldnt click
reverse has no synchros or any fancy gears on
make sure ur oil level is good
does it go smooth into reverse??
maybe broke something inside, or there some shaft play in there as in some bearings or something..
try agian and give us a more detailed update
Maybe check out your CV Joints? I say put it up on a lift, or put the front on stands and run through 1st and Reverse while a friend cautiously and carefully listens around the car to find the sound's source.
