Final suspension choice!
Old Oct 31, 2001 | 10:29 PM
5-SpeedFreak's Avatar
New User
Default Final suspension choice!
I finally made my decision as to what to install on my '01 GSR. I chose to buy Koni Yellows and Eibach sport springs.
Good choice Y/N? Please give me some feedback before I spend the moolah!
Thanx!
Old Oct 31, 2001 | 11:22 PM
2005 TSX's Avatar
Your setup sounds like the common route that many people have taken here on this board. I have yet to modify my suspension to that extent, but I think most people are going to tell you that it is a good setup. If this if your final choice, I am sure you could find a good deal on what you are looking for in the classifieds or best buy section.
[Modified by 2001 Integra GSR, 12:24 AM 11/1/2001]
Old Oct 31, 2001 | 11:43 PM
FLIP2daMaX's Avatar
Default Re: Final suspension choice! (passion4healing)
could choice.....my set up is the same on my EG....i love how the shocks are adjustable.....i live near a city notorious for potholes and shity roads...< D.C. > but the koni's help me out, even on the softest settings ( just a notch harsher than stock ) u can carve turns w/ ease....
Old Nov 1, 2001 | 12:24 AM
New User
Default Re: Final suspension choice! (FLIP2daMaX)
Thanks for the feedback!!!
Old Nov 1, 2001 | 07:52 AM
Leimokei's Avatar
New User
how much is your setup going to run you? if its around get $800...get a full damper kit...be worth it...
Old Nov 1, 2001 | 08:00 AM
BoM's Avatar
BoM
Default Re: Final suspension choice! (Leimokei)
i got AGX's with sportlines, cause their cheaper
i really didn't see the use of KONI's for my app.
if i were to get higher spring rates i'd have to use koni's
yeah for that price u can almost get a full coilover system
Old Nov 1, 2001 | 09:17 AM
New User
I'm getting the setup for 400$ from a friend of mine. The springs/struts were installed for a short time on his car, and he decided he wanted to go lower....
Old Nov 1, 2001 | 10:39 AM
Black SVT's Avatar
If you are just wanting to lower the car that isn't a bad choice.I am not sure what spring rates you are getting but if you are looking to improve the handling you might want to be picky on the spring rates.
Old Nov 1, 2001 | 12:24 PM
PaChiLa Leader's Avatar
Get a set of TEIN HA (springs and coilovers)
[Modified by PaChiLa Leader, 9:25 PM 11/1/2001]
Old Nov 1, 2001 | 05:26 PM
George H's Avatar
By sport springs you mean the Sportlines, right? If so then I'm sure you will like it. It will give your car that "slammed" appearance but it really wont slam it. You should end up with a 1 finger gap up front and a 1/2 finger gap in back. If you want something a little less agressive then I suggest the Eibach ProKits. Other than that you made an excellent choice on the shocks. The Koni's are worth their weight in gold.
Old Nov 1, 2001 | 05:39 PM
immortal's Avatar
Banned
Default Re: Final suspension choice! (KANJI)
i have the pro-kits and koni reds.
Old Nov 1, 2001 | 08:28 PM
gsrpowered95's Avatar
New User
Default Re: Final suspension choice! (immortal)
Anyone tell me retail price for koni yellow's I am looking to do some yellow's to go with my neuspeed race springs.. I got a screaming deal from this pmpdesign place in cali.. full set of neuspeed race springs for $75 shipped to my door god I love ebay!
Old Nov 1, 2001 | 10:35 PM
rockwilda's Avatar
Default Re: Final suspension choice! (gsrpowered95)
koni yellows usually go for ~500
Old Nov 1, 2001 | 10:45 PM
New User
Thank you Kanji, that is the feedback that I'm looking for!
I will be picking up the set in the next week or two, and will let you and H-T know how I like em'.
I'm sure I'll be thrilled with the handling of the car. I like the stock handling, but want a tighter feel.
Thanks again!
Old Nov 1, 2001 | 11:12 PM
ALF's Avatar
ALF
I have the suspension setup you're getting and it isn't "slammed" at all. 2 finger gap all around. It looks nowhere near as low as the ricemobiles I see all the time. And surprisingly, I still get GREAT ground clearance...it's a perfect balance.
Make sure you put the rear shock perches at their highest setting or the front will be higher than the rear.
Old Nov 1, 2001 | 11:50 PM
masterxfob's Avatar
Default Re: Final suspension choice! (Dozed)
wow........$400? that's a damned good deal, i just bought a new set of koni's from guyuenvy for $500. how come my friend's aren't as generous as yours, hehe. yeah, but that's also the same setup i will have when i get the shocks.
Old Nov 1, 2001 | 11:51 PM
leechungsr's Avatar
The sportlines will look very dropped, and you would most likely need a camber kit.
Pro-Kit provide nice drop, nice handling, and left good clearance when I had a Wings West lip
Old Nov 1, 2001 | 11:59 PM
New User
I was told that the springs will lower the car 1.2" Y/N?
I DO want ground clearance! That would suck fuc--ng up the header/exhaust that I wanna buy down the road...
Old Nov 2, 2001 | 12:13 AM
mafay2's Avatar
New User
Koni is not bad, but when compare the TEIN NA I have now to the Koni/GC combo I have before. The TEIN is much better.
They both cost around the same, the only different is TEIN NA is not a coilover and can't adjust height like the GC did.
Old Nov 2, 2001 | 12:45 AM
Anthony K's Avatar
New User
Default Re: Final suspension choice! (mafay2)
Sounds like you'll have a pretty worthy setup. The Eibachs are very nice but I really really like my Ground-Control coilovers because of the height adjustability.
Old Nov 2, 2001 | 12:59 PM
FLIP2daMaX's Avatar
this is some what of the subject, but i know from experience, as does "Dozed" nd another friend of mine,
that the weak a$$ factory BOLTS for the rear shock on the lower control arm has a tendency of braking.....damn bolts cost $11 at the dealership.....if u'r gonna do the installation, i suggest u treat the bolts from their FROZEN state to make the application smother....."learned the hard way"
Old Nov 2, 2001 | 02:35 PM
masterxfob's Avatar
frozen state? what's that mean? i need to know because i'm going to be installing my koni's when i get them.
thanks
Old Nov 2, 2001 | 04:07 PM
New User
Default Re: Final suspension choice! (masterxfob)
My car is 3 months old, the bolts shouldn't be frozen yet....
And it's been summer here in California... It hasn't been below 32 degrees!
No freezing here....
Brrrrr
Old Nov 2, 2001 | 10:13 PM
kikkoboyie's Avatar
New User
I think your mistaking sportlines for pro-kit? a pro-kits drop is about 1.2 inches, little more after it settles...
Old Nov 2, 2001 | 11:39 PM
New User
Default Re: Final suspension choice! (kikkoboyie)
That may be a possibility.. I can only go with what my buddy has told me. He did say that it's a 1.2" drop, and that they are Eibach springs.
When I pick them up, I'll know for sure. Either way, it'll be better than the stock setup I have now.
400 bucks, can't turn it down!
