92 Civic DX Shock Tower VTEC Wiring??
Old Apr 26, 2004 | 05:35 PM
raider099's Avatar
Default 92 Civic DX Shock Tower VTEC Wiring??
just almost finished swap. i have a 92 dx with gsr swap, i used the stock dx engine harness. I was thinking that the vtec wires will already be on the internal civic harness, i just cannot locate them at the shock tower plugs. I searched and came up with this info regarding the wires.
vtec solenoid = green/yellow = A4
vtec oil pressure = blue/black = D6
knock sensor will not be there. = D3
so i have looked for these combonation of colors in the wires at the shock tower plug, i cannot find them.
I also am not able to locate these wires on the ECU Plugs.
I have a 92 civic hatchback dx. i just converted it to manual. Has the OEM DX Harness.
Can anyone help me
Old Apr 26, 2004 | 08:01 PM
VTECVillain's Avatar
Default Re: 92 Civic DX Shock Tower VTEC Wiring?? (raider099)
Yes ALL 92 model's are prewired from the ECU to the shock towers for VTEC sensors. If you buy a Helms electrical manual for a 1992 Civic, you could easily map out the shock tower pin positions for the wiring. You might be able to find the exact info on here on h-t if you search long and hard.
Old Apr 26, 2004 | 09:45 PM
Turbogixxer's Avatar
Default Re: 92 Civic DX Shock Tower VTEC Wiring?? (VTECVillain)
Old Apr 27, 2004 | 07:33 AM
stevel's Avatar
Default Re: 92 Civic DX Shock Tower VTEC Wiring?? (turbogixxer)
nice info!!
I'm sure I even have it written down but that's a great pic. Really helpful.
thanks.
s
Old May 4, 2004 | 12:07 PM
raider099's Avatar
Default Re: 92 Civic DX Shock Tower VTEC Wiring?? (stevel)
thanks guys, now this looks clean in the bay
Old May 6, 2004 | 09:57 PM
icucnme's Avatar
OMG thank you. I just did this swap today and all that is left is vtec and oil pressure and I'm done.
Old May 7, 2004 | 07:47 AM
raider099's Avatar
Default Re: (icucnme)
dont forget the knock d3, that is if your using a ecu that looks for one.
Old May 7, 2004 | 10:37 AM
Katman's Avatar
glad my image helped
Old Jun 21, 2004 | 03:00 PM
Tyreece04's Avatar
Default Re: (Katman)
great image thanks forpics!!!do you have any ideas where a ks is pinned into a p28?????
Old Jun 21, 2004 | 03:14 PM
Default Re: (Tyreece04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyreece04 &raquo;</TD></TR><TR><TD CLASS="quote">do you have any ideas where a ks is pinned into a p28?????</TD></TR></TABLE>
It does not read a Knock sensor so you do not have to wire it up.
Thank Katman, not me for that diagram
yusoslo
Aug 18, 2004 10:25 AM
mattssi
14
Mar 24, 2004 07:00 AM
Integra_Boi
10
Oct 3, 2003 05:47 PM
South Bay Surfer
Nov 23, 2002 01:08 AM
4banger
Sep 27, 2001 11:14 AM
