Removing EG window handles??
Old Apr 26, 2004 | 05:34 PM
Tad's Avatar
Tad
Default Removing EG window handles??
OK how the FUUUCKK do you get these things off!!
helms says you have to use a wire clip.. to grab onto another wire inside the handle, and pull on it while you pull the handle out..
well I made a wireclip out of a coat hanger and sat there monkeying around inside of the handle forever and could not get it to go!
its impossible to see in that thing, and feelign around, I just couldng find what I was supposed to hook onto.
anyone have any tips?
note: I mean the manual wind up window handles.. 92-95 civics
Old Apr 26, 2004 | 05:36 PM
B_CRUZ!'s Avatar
Default Re: Removing EG window handles?? (Tad)
get a rag a wedge it between the handle. pull each side of the rag one after another and the clip will pop out.
<--I suck at explaining things online.
Old Apr 26, 2004 | 05:39 PM
Tad's Avatar
Tad
Default Re: Removing EG window handles?? (b cruz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b cruz &raquo;</TD></TR><TR><TD CLASS="quote">get a rag a wedge it between the handle. pull each side of the rag one after another and the clip will pop out.
&lt;--I suck at explaining things online.</TD></TR></TABLE>
heh, ok that sounds cool..
but i'm not sure exactly what you mean,
if you could describe alittle better exactly how that rag should be wedged in there...
thnx
Old Apr 26, 2004 | 06:06 PM
xerox445's Avatar
Default Re: (civic_rice)
i just rip mine off, my little clips suck
Old Apr 26, 2004 | 06:07 PM
Ricey McRicerton's Avatar
I have some surgical clamps that I use to pop the U pin out. Some thin needlenose pliers would also work.
Old Apr 26, 2004 | 06:12 PM
xerox445's Avatar
Default Re: (Ricey McRicerton)
i actually have the correct tool to take them out, its like a flat piece of metal
Old Apr 26, 2004 | 06:16 PM
Tad's Avatar
Tad
aaah ok I think I understand,
so basically wedge the tool(rag.. plyers, etc) in and push on the OPPOSITE side of where the handle points to.
I'll assume thats right cuz the helms diagram shows you pulling the pin out from the direction the handle is pointing.. so naturally push it from the other end.
haha, ok i'll go try,
too bad also the screw holding on that little plastic pocket on the door is ******* stripped and wont come out.. grrrr,
tried drillin.. the little bastard must be forged or some ****.. probly gonna end up with bloody knuckeds breaking it
Old Apr 26, 2004 | 06:55 PM
Justin Jones's Avatar
Default Re: (Tad)
i bought the correct tool to take them out (kinda like a flat piece of metal with some triangles cut in it) but i ended up driving two doors down from my house to the local PRO bodyshop and they just use a hooked scratch-all type thing... worked like a charm. i still haven't put the cranks back on, lol. what a pain in the *** it is to be driving along and getting the passenger to pass you a window crank... LMFAO.
Old Apr 26, 2004 | 07:09 PM
heyyou82's Avatar
yeah, somebody else already said it, but i usually use a pair of forceps, the clamp like things they use in surgery. they are pretty strong, and lock in place, and are pretty pointy, so you can get them between the handle and the door panel.
another good thing i have found is to find an old steak knife, one that is pretty pointy. bend the tip 90 degrees, or even a bit more, making a hook. then, hook that on to the metal clip, and pull it off!
Old Apr 26, 2004 | 07:12 PM
5w20's Avatar
Default Re: Removing EG window handles?? (heyyou82)
pull the handle away from the door as far as possible and then with some needle nose pliers and a flashlight (to see) pull the little clip off.
Old Apr 26, 2004 | 07:15 PM
splitime's Avatar
I just open the door wide so i have room.
Make sure the handle is up or up and facing the rear of the car some.
Then pull it back a bit and use a eyeglass sized screwdriver to pry the clip in and up at the same time.
Old Apr 26, 2004 | 08:03 PM
slowhatch4now's Avatar
Default Re: Removing EG window handles?? (splitime)
i use the rag trick, the thing i used to do before that was the THin *** hook and pull the clip off
peace
Old Apr 27, 2004 | 12:09 AM
Tad's Avatar
Tad
a'aight, coo,
I got one of em off,
thought the hook was over that plastic washer thingie.. but it was actually under..
... meh.
myflyintegra
Jan 14, 2009 02:21 PM
mustang5.slow
Apr 3, 2007 05:10 PM
Lookinaround
Aug 1, 2006 08:10 AM
90gs
Dec 5, 2005 03:58 PM
MastrDB8r
Feb 25, 2004 11:15 AM
