pinging on 10:1 compression b18b with 7 psi. what can i do about it?
Old Apr 26, 2004 | 04:43 PM
ccsmith1999's Avatar
Default pinging on 10:1 compression b18b with 7 psi. what can i do about it?
well i have no idea why this pings like crazy after 5k rpms but it i have rc 310s and the crower 402ts installed. i am running a 255 lph fuel pump. i have a big *** intecooler from the turbo kit from rev hard. this is especially on 7 psi. is revhard any good? how can i prevent pinging? i know the timing is 16 degrees btdc. what should i set it at? how can i set it without msd?
Old Apr 26, 2004 | 06:05 PM
MaxSterling's Avatar
Default Re: pinging on 10:1 compression b18b with 7 psi. what can i do about it? (xeugep)
i would check the cam timing marks w/ crank, and then check timing with gun.
Old Apr 26, 2004 | 06:49 PM
J337_UNIT's Avatar
what kind of engine management are u using?
Old Apr 26, 2004 | 07:14 PM
Default Re: pinging on 10:1 compression b18b with 7 psi. what can i do about it? (J337_UNIT)
all i have is a fuel pressure regulator
Old Apr 26, 2004 | 07:15 PM
http://cgi.ebay.com/ebaymotors...%3AIT
thats what i got on ebay
Old Apr 26, 2004 | 08:20 PM
psi420's Avatar
Your running stock timing. I would atleast set it at 13-14deg.
Are you running colder plugs?
Old Apr 26, 2004 | 08:35 PM
Default Re: (psi420)
i have them nkg r spark plugs, the guy said they are stock plugs for that engine
Old Apr 26, 2004 | 10:18 PM
turbopro's Avatar
definately run a colder plug, gap them at about .027 that should help u out, are u sure its even pingin 7 psi aint much even at 10:1 compression
Old Apr 27, 2004 | 10:06 AM
psi420's Avatar
Yah, get some BKR7E's for $2 a pop.
And pull some timing back, that should help a ton!
Old Apr 27, 2004 | 03:33 PM
b_ron007's Avatar
sounds like ur plugs definitely.
Old Apr 27, 2004 | 04:00 PM
ekb18c's Avatar
pull some timing off and did you install the FMU that came with the kit?
Old Apr 27, 2004 | 04:19 PM
Muckman's Avatar
Moderator in Chief
its deff your spark plugs. thats not alot of boost and "stock gap" plugs will deff cause pinging. Run the ever so common NGK BCPR7ES-11 plugs and gap them at .032"
Old Apr 27, 2004 | 04:25 PM
Blaze45's Avatar
Brrraaaap!
Default Re: pinging on 10:1 compression b18b with 7 psi. what can i do about it? (Muckman)
Wait, you dont have any fuel mods accept for a fuel pressure riser? Did you install the vortech FMU that came with the kit? If you dont have anything that can add fuel I would gett something that can add more fuel. I would also run a higher octane fuel and retard the timming so you dont blow up your motor.
Blaze
edit ok I thought you said fuel pressure riser, sorry. You might want to try a differnt disc that adds more fuel or bumps pressure so that fuel is added.
Old Apr 27, 2004 | 04:26 PM
psileepR's Avatar
New User
88 crx, b18 cable tranny ls with crower 403 cams, stainless steel 1mm oversized valves, head milled 40 thousanths, approximately 10:1 compression ratio, walbro 190 fuel pump, integra cluster conversion... going turbo in about 1 month
your head is milled so your timing is off. retard the base timing for now to be safe like the others have suggested. colder plugs . gapped to like .030 until you have a better form of engine management.
gl
Old Apr 28, 2004 | 05:20 PM
Default Re: pinging on 10:1 compression b18b with 7 psi. what can i do about it? (psileepR)
does milling the head, advance the timing or retard it?
walrus_07
Oct 25, 2011 11:16 AM
zcpowereddx
Dec 23, 2003 08:57 AM
[HrZn]4life
Apr 11, 2003 04:40 PM
Neukin
Mar 5, 2003 06:04 PM
foreverjenn
Sep 28, 2002 09:06 AM
