How to take out ignition coil
Old Apr 26, 2004 | 03:43 PM
Pete_SI's Avatar
Default How to take out ignition coil?
Hi,
I need to change my coil and when take the ignition cap off there is this black cap that surounds the coil and I cant take it out. Help me plz.
BTW it's a 2001 CRV engine.
Old Apr 26, 2004 | 03:48 PM
blapblap!!!'s Avatar
Default Re: How to take out ignition coil (Pete_SI)
you have to unscrew the bolt in the rotor..it's on the side through an opening... then the rotor and that black covor comes off... then unscrew the wiring and unplug others... at this point it should be obvious... good luck man
Old Apr 26, 2004 | 03:53 PM
Pete_SI's Avatar
Default Re: How to take out ignition coil (blapblap!!!)
I took the 2 top bolts out but all the other bolts seems to be out of place to take out.
Old Apr 26, 2004 | 04:28 PM
Pete_SI's Avatar
Default Re: How to take out ignition coil? (Pete_SI)
Found it
Old Apr 27, 2004 | 06:15 PM
well good man... let me know if you need any help with anything else...
Lb1atx
Jul 19, 2007 07:59 PM
civiccoupe94
Feb 3, 2006 05:34 PM
turbo sol
May 5, 2003 06:38 AM
gtconcepts
Dec 7, 2002 04:31 PM
