Closing tranny Case
Old Apr 26, 2004 | 01:20 PM
ultimatehonda's Avatar
Default Closing tranny Case
I just changed my ISB and now im putting everything back and The case does not go all the way down. Its not the snap ring because the ring hasnt even touched the bearing yet. What can this be? Any help would be great
Old Apr 26, 2004 | 02:23 PM
Default Re: Closing tranny Case (ultimatehonda)
someone?????
Old Apr 26, 2004 | 03:49 PM
TTT
Old Apr 26, 2004 | 04:46 PM
Dan GSR's Avatar
i see an Si in your sig
is this a b16 tranny?
there is a washer on the main shaft, that has a notch in in. make sure that it lines up with the notch inside the transmission case
Old Apr 26, 2004 | 05:51 PM
Default Re: Closing tranny Case (Dan GSR)
yeah all that is good. I finally was able to close the case and put the snap ring on the counter shaft. Now once I had the tranny fully built, the mainshaft does not spin??? Why can this be?
Old Apr 26, 2004 | 06:08 PM
Dan GSR's Avatar
obviously something is not right
open it up and double check everything
Old Apr 26, 2004 | 06:14 PM
i have....and i follow the helms to the T and nothing??? What I did today was replace the ISB and the angular bearing on top of the mainshaft. I also replace the spring washer and washer that goes on top of the ISB. Is it possible I have the ISB backwards?? I have it right now with the little letters that are etched on it facing up. Does that matter?
Old Apr 26, 2004 | 06:29 PM
Dan GSR's Avatar
yes, etching should face up
is the spring washer facing the right way?
Old Apr 26, 2004 | 07:14 PM
yes the spring washer is right
Old Apr 26, 2004 | 07:16 PM
The main shaft only locks up when the lock ring is in place and some bolts are on. When the case is just a lil bit open it spins. I also loosened the counter shaft bolt but I tighten it back down and torqued it? Would that have anything to do with it?
Old Apr 26, 2004 | 07:28 PM
Dan GSR's Avatar
is the circlip fully seated?
Old Apr 26, 2004 | 07:36 PM
Which circlip?
Old Apr 28, 2004 | 06:36 AM
I assembled the tranny with the main shaft only and it locks up. The tap on the washer up top is aligned with the case, and the bearing is seated all the way down just and just sticks out a little bit. Why would the mainshaft bind when the tranny is closed???
Old Apr 28, 2004 | 10:50 AM
acy76's Avatar
Are you sure the input bearing and the top mainshaft bearing are properly seated (especially the input bearing)? If the input bearing is not seated fully or is at an angle to the seat it might cause a bind. My best guess...
EDIT: Have you checked the runout on the mainshaft? I have heard of bad input bearings causing excessive runout.
Old Apr 28, 2004 | 12:39 PM
Default Re: Closing tranny Case (acy76)
I have not checked it but the main shaft was spinning before I opened it. Now when I put it back together it binds up.
Old Apr 28, 2004 | 12:51 PM
Big Teggie's Avatar
Make sure everything on the mainshaft is seated correctly.
Did you check the mainshaft thrust clearance. I always check to make sure everything is good when changing anything on the mainshaft.
Old Apr 29, 2004 | 07:28 AM
Default Re: Closing tranny Case (Big Teggie)
I didnt check it because I think u need a special caliper to do it. I have spent the whole week dealing with a smiple job like this....I just finished droping the tranny at a shop to see what they can do for me....I just hope they can fix it.
sanman000719
Transmission & Drivetrain
Feb 7, 2010 04:34 PM
ultimatehonda
Apr 30, 2004 08:03 AM
AlphaKennyWun
Nov 28, 2002 08:29 AM
SoloSol
Jan 28, 2002 07:16 AM
