HOW-TO...EK windshield wiper fix for posessed wipers.....
While not that many people seem to have this problem even fewer knew how to fix it so here goes....
Problem: wipers won't stop, they've been acting weird lately..starting on themselves and then just full on, you've fiddled with the switch, perhaps kicked around under the dash looking for a relay of some sort, but the only solution you've found so far is to turn the car off or yank the fuse.
Troubleshooting:
According to the manual it can be one of 3 things.
1. the switch--this wasn't the problem with mine, but I would assume that they would either be stuck on or stuck off, whatever position they were in when it malfunctioned. the book says that if you unplug the switch and the wipers turn off then that's your problem. mine stopped with switch unplugged and then started with oem-new-switch replaced
2. Integrated Control Unit-- again, not the problem with mine. I think this just has to deal with the intermittent feature and controlling how the wipers park, nobody seems to know a damn thing about these, but I do know that if you unplug the plug going into the back of it (and you're having the same problem I was) you gain manual control of wipers (won't park/won't auto-on with washers/intermittent).
3. The bastard wiper motor-- in the end, part of this ended up being my problem. if yours aren't coming on at all, I would recommend first checking the fuse and then checking the motor. the wiper motor plug has 5 prongs, three on top(1-3) and two on the bottom (4&5). With harness removed apply power to pin4 (bottom left) and ground to pin1 then pin2(top left and center). if the wipers move then there's hope for it yet, even if it is a little bastard...
Quick Fix If you're having the same problem that I had you can regain manual control of the wipers by unplugging the ICU.....
--plug looks like this--
--icu looks similar to this, it's on the back of the underdash fuse panel (one in pic is teg)--
--icu in car(back of fuse panel), arrow at plug that needs to be removed, yank that bitch--
Congrats, your wipers now work somewhat....... onto a more permanent fix.
Fixing the bastard wiper motor
This can be done with with wiper motor and linkage still in car, I removed mine cause I'm a dumbass and thought I had to.....
--pic of wiper motor dissasembly, remove three t20 screws and pry up...watch the goo, note the position of the white disk... not sure if it matters but it very possibly could...--
--bastard torx screwdriver needed--
--on the part just removed, note position of arm 2 (at bottom) the one in the pic is fixed but I bet yours is making constant contact at the end (yellow dot), if so, gently bend at or near the X. If you weren't gentle enough you'll need to solder it back on (oops)--
--here's an attempt to show the way it should look afterwards, make it so it has the same gap after adjustment as the other, then test by spinning the white disc, make sure it contacts--
Now, just put the cover back on and make sure they work, button everything back up and you're done. You just saved yourself around $100, **** $250 if you planned on taking it to honda.
How long do they last after fix, hell if I know..... we'll see I guess...
edit... sorry it's soo frickin long
Modified by miahmouse at 11:26 PM 4/26/2004
Troubleshooting:
update: Fix lasted till just last week. So it's a decent temp fix and it can probably be done better. If you have the money, go ahead and buy a new damn motor. Another think to keep in mind is that if you unplug the ICU the idiot buzzer for the headlights on no longer works...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrissleame »</TD></TR><TR><TD CLASS="quote">awesome write-up.it's not long.i like detailed writeup.
yeah definately... I might try on my 93, the intermittent wipers stopped working and they arent working as needed
</TD></TR></TABLE>yeah definately... I might try on my 93, the intermittent wipers stopped working and they arent working as needed
i had the same prob with a customers car at my work. luckly when i called honda for the part the parts guy said they replace so many motors ( I was initially thinking switch) due to them sticking on. anyway nice write up
This just happened to mine today. Stuck on.
I can hear the relay click under the dash when I move it to the intermittant setting, so that confirms the switch works. That and the high setting works.
So in the off position its like its on low
In the intermittant position its like its on low
in the low position, its like its on low
and the high position works
I did find that if you move the selector **** inbetween settings they will shut off. Looks like my problem is the motor as described above. Time to take the little bastard apart. Thanks for the write up!
back from the dead...........
my wiper comes on automatically when I turn the key but I think i need a new ICU beacuse I no longer hear the beeps when the headlights are on and when the door is open
Can someone tell me where the ICU is located or a part number?
I have replaced the wiper motor and switch but my wipers still come on with my headlights. The car is a 2000 Civic.
Thanks,
Kyle
Thanks,
Kyle
Just to let people know, there is a TSB out for certain years of 6th gen Civics.
The return switch in the motor breaks.
This means that when you turn the wipers off they NEVER return to where they belong. Some settings might not work, while others do. On mine, for example, the high speed worked, but not the lower speed which I usually used.
The solution for this issue is to replace the wiper motor.
Hmm I got an issue where when i shut my wipers off the go down and come back up 3 inches. Is this related or is it just someone removed the linkage and didnt put it back on right.
I finally fixed my windshield wipers. I replaced the wiper motor, ICU, and the control switch but no luck.
It turned out to be the ground wire that is behind and just below the driver side headlight. I cleaned up the the ground wire and everything works great now. KISS!
I had this problem on a 98 Accord. The wipers were always on low (all settings but high). Found a broken intermittent wiper relay, it`s near the brake booster.
this is some bullshieeeeeeeeeeeeeeeeeeeeet.
crazy *** weather in cali right now and i cant drive cuhs my wiper blades dont turn on at all!!!!!!!!
i replaced the fuse.wasnt that
took out the motor and connected it straight to the battery mother****ers started moving....
so im thinking it has to be some wiring? or i could be wrong
i was also thinkin about the on/of switch cuhs my sprayer dont spray either, could that possibly be ****ed up or something?
any help would be great...
im tryina drivvvvvvve again!
Sorry, I can't post pictures right now.
From a electrical schematic diagram, you can see why the wipers stay on. The wipers are always powered to allow the return to bottom position. A relay above the motor housing has a simple broken/bent copper arm on a circular position disk. It's was unfortunate that the entire motor has to be replaced, since the mechanical relay could not. Send me an e-mail and I might be able to show you some photos, I'll post when I'm allowed.
I have a problem with my windshield wipers on my eg hatch. Everytime I hit bump on the road my windshield wipers go off. I guess it's loose but how can I fix that.
