DPFI to MPFI, using the si engine harness and repinning ?
has anyone used the si engine harness and then repinned the wires where the harness plugs into the car harness by the firewall? is there a reason this can't be done?
It's a PITA and not worth the effort. It's just not repinning. You would have to run wires on your underdash harness to accomodate the OTHER firewall plug that is located on the driver side of the car. DX's don't have that one at all.
If you take your time and convert the DX harness then you can make it look just like it was OEM. No real point in wasting time on the Si harness.
you mean take the MPFI harness and put the mpfi pins into the shock tower plugs? then use the stock b series or d16a6 motor harness to plug into it? if that what you mean, thats how i do my vtec swaps. i take the pins out of an old harness and plug them into the clips, then vtec motor harness is plug and play.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elmalouno »</TD></TR><TR><TD CLASS="quote">alrighty... just wondering cuz i am about to start this headache.. heh.
Yea let us know... Do a write up on it, i think u would be the first
</TD></TR></TABLE>Yea let us know... Do a write up on it, i think u would be the first
EFing_Slow
Nov 1, 2016 06:41 AM
CRX91SE
Mar 31, 2011 10:29 PM
ITR981002
Jan 27, 2004 07:48 AM
