Is 22.5K a good deal for This blue S2K?
I can get a 02 Suzuka Blue S2K w/ hardtop and 38K miles for $22500.00
Is it a deal I should take? The only thing I can see wrong with it is that the shifter shakes like crazy when it's in gear... Otherwise there is just a rock dent/chip on the hood...
Should I take this?
There is also a Red 02 with 37K miles for 22K
what do you guys think?
Should I take this?
thats not bad at all i'd try getting it to 22 flat...
check the vin number to see if its made with the 4 oil jets bolts made mid 2002 year. also check for 2nd gear grind.. test it out for ease of putting in gear and putting in gear at high rpms (getting on it) i know honda "fixed" the 2nd gear grind for 02 but it seems like a quick fix to me
I think I decided on the red one... the VIN is JHMAP11412T001083
How do I check for the 4 oil jets bolts?
What does it do? or fix?
Thanks
Thanks
the last 4 digits indicate the number of the car of the model year..
im not sure with 1043.. could be too early
the 4 jet oil bolts were added since during the 00-01 there were a couple cylinder 4 failures due to lack of oil. they replace the older models 2 jet oil bolts
antaren
Sep 28, 2007 06:48 AM
