Noob question about raising compression and A/F ratio
Old Apr 26, 2004 | 10:33 AM
Stock@$$GSR's Avatar
Default Noob question about raising compression and A/F ratio
now I don't know if there's an actual correct answer to this, because I know a lot "just depends" on the setup, but in general (if there's a such thing), if you raise compression in a GSR motor to 11.5-12:1 and keep a stock GSR ecu in there, what happens to the A/F ratio? I'm assuming it can only do 2 things, either run leaner or run richer. Which is it?
Old Apr 26, 2004 | 09:54 PM
Default Re: Noob question about raising compression and A/F ratio (Stock@$$GSR)
anyone?
Old Apr 26, 2004 | 11:37 PM
xplanetearth420x's Avatar
alright please do a search i see stuff about a/f ratio all the time search and search arcives
Old Apr 27, 2004 | 12:18 AM
Default Re: Noob question about raising compression and A/F ratio (xplanetearth420x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xplanetearth420x &raquo;</TD></TR><TR><TD CLASS="quote">alright please do a search i see stuff about a/f ratio all the time search and search arcives</TD></TR></TABLE>
thanks for the reply, but I actually searched the archives and couldn't find the answer to my question. most of those posts ask about tuning they're a/f ratio, where i'm technically asking a non-tuned a/f ratio question.
Old Apr 27, 2004 | 02:44 AM
lingerbw's Avatar
I would be interested in this, too. I am increasing the compression in my F22 to 11:1 and (initially) will be using stock ECU with stock a/f maps. Anyone know the impact?
Old Apr 27, 2004 | 08:55 PM
Default Re: Noob question about raising compression and A/F ratio (lingerbw)
tuning pro's, where ya at?
Old Apr 28, 2004 | 03:08 PM
someone's gotta know!
Old Apr 28, 2004 | 05:49 PM
FerioVtec94's Avatar
i was wondering this also
Old Apr 28, 2004 | 08:27 PM
743power's Avatar
Default Re: (FerioVtec94)
Well, I'm not an expert, but I'll take a shot and hopefully an expert will correct my errors.
An engine with a higher compression ratio is more efficient and therefore it should require less fuel to produce power.
However, when you increase compression, you also increase the density of the air/fuel mixture, and combustion speed, and lower the vacuum in the cylinder, which should result in a richer fuel mixture.
civickid03
Jan 28, 2007 12:55 PM
moehp
Jan 6, 2007 09:35 PM
Tzarinque
Oct 17, 2006 12:46 PM
JurakS
Jun 12, 2003 12:50 AM
integraL
May 18, 2003 08:17 PM
