Modified exaust ticket question
Old Apr 26, 2004 | 09:27 AM
TypeRPaul's Avatar
Default Modified exaust ticket question
i just recently recieved a ticket from the highway metermaids (CHP) and was curious if there was any other way to lower my emmisions and sound with out adding a second cat. i was wondering if adding some metal screens in between the cat and my exaust would change anything? or is their anyother way? btw i have an apexi N1 on my ITR. for the full story search TypeRPaul in the ITR form
thanks all,
Paul
Old Apr 26, 2004 | 01:21 PM
TypeRPaul's Avatar
come on someone must have an idea
Old Apr 26, 2004 | 01:24 PM
doublejz's Avatar
Default Re: (TypeRPaul)
resonator, or a bigger one
Old Apr 26, 2004 | 03:29 PM
dfoxengr's Avatar
Default Re: Modified exaust ticket question (TypeRPaul)
if you have a cat, then they cant get you for smog issues. anything after the cat has no effect on pollution.
Old Apr 26, 2004 | 03:40 PM
Kal's Avatar
Kal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">resonator, or a bigger one</TD></TR></TABLE>
double resonators work well too.. it will cut down the sound but will not help with emissions.
Old Apr 26, 2004 | 04:32 PM
sporkcrx's Avatar
Default Re: Modified exaust ticket question (Kal)
Also, now when you get an exhaust ticket you can get your car tested, and if it passes the dB limit you'll get a certificate that you just show the next time you get pulled over. And they can't do nothin!
Old Apr 26, 2004 | 06:08 PM
98-ls's Avatar
Default Re: Modified exaust ticket question (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">Also, now when you get an exhaust ticket you can get your car tested, and if it passes the dB limit you'll get a certificate that you just show the next time you get pulled over. And they can't do nothin! </TD></TR></TABLE>
good luck passing with an n1
Old Apr 26, 2004 | 07:56 PM
TypeRPaul's Avatar
Default Re: Modified exaust ticket question (98-ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98-ls &raquo;</TD></TR><TR><TD CLASS="quote">
good luck passing with an n1</TD></TR></TABLE>
so i have heard, is there anythin, like a silancer i can fab up that is inserted in after the cat, but not at the tip, so they wont know it is removable? so after i get the certificate i can just drop it and pull it out? sounds like it would work to me, but what do you guys think?
Old Apr 27, 2004 | 08:44 AM
TypeRPaul's Avatar
anyone have an idea?
Speed94
Nov 12, 2006 04:02 AM
tomlinson619
Jul 19, 2006 12:29 AM
beat_nut
Nov 24, 2004 11:02 PM
EJ8 GSR-T
Nov 22, 2004 03:58 PM
VsR785
Mar 8, 2004 02:19 PM
