friends battle with Alterators Vs. AEM Alt. pulley
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">The pulley is balanced, could be tearing up the assembley. Thats my guestimation.</TD></TR></TABLE>
Isn't.
Isn't.
sounds like something is causing them to burn out rather fast. does he have a couple subs etc? I had a pair of subs in my old 90 cavalier and I burned out two alts cuz they drew too much power and the alt was trying to compensate for it
does he have an aftermarket crank pulley?...i think the aem alternator pulley is smaller in diameter to the stock and that makes the alt spin faster and burn out,i have seen this happen before..i would call aem and talk to them about it
aem pulley is bigger than the stock pulley. Lemme see if I can get my scanner to scan up my aem that I have (it's on an alt now just not in the car) and compare with the stock. Should take me 20 minutes or so then I should have a pic
edit: Here ya go
larger than stock, means less amp output, means if you're trying to push some good amps outa it, you're gunna burn it out. Hmm, might need to find a high amp alt before I put this thing in.
edit: Here ya go
AEM doesn't make a crank pulley. http://www.aempower.com/faq.asp?fid=28&sid=&tid=4 . Check in their forum to see if anyone has had this problem or contact them directly.
the alt pulley is bigger cuz it's easier to turn...just like the gears in the tranny or on a bike... bigger gears are the easiest to turn so there's less drag. that's the whole reason for the pulley.
Like I said, it's turning less, so less efficient=less amps. If you're drawing more than it can put out, you're gunna burn it out. I doubt it's the fault of the pulley.. Heck, don't they recommend using a higher amp alt on the aem site? I'm pretty sure that's what I read...
"Question
Will this upgrade cause my battery to die?
Answer
No. The effect of the Pulleys at idle is minimal. The only time there may be a problem is if there is a very high demand on the electrical above and beyond the stock design. This would include very high power sound systems or similar devices. Of course you should make sure the charging system of the car is in good condition. "
Now for a crank pulley, try the dh-racing or unorthodox ones, that might actually ballance out the mix.
"Question
Answer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman »</TD></TR><TR><TD CLASS="quote">thats wierd i never seen an alt pulley that big(what were they thinking)lol..ya i would try a smaller crank pulley or like what someone said to get that other alternator.</TD></TR></TABLE>
from overboosts website on aem pulley install
looks to be the same size as his
neofreak
33
Jan 12, 2007 01:47 PM
