Budget Buildup any suggestions?
Old Apr 26, 2004 | 06:21 AM
f22suzuka's Avatar
Default Budget Buildup any suggestions?
I was going to go turbo, but after witnessing a few mishaps with friends cars I decided to go back to naturally aspirated, I know my integra is heavy and won't be fast but I am just looking for some added midrange/top end power. So far I have Short Ram intake/DC 4-2-1 Header/Greddy exhaust. Not the best set-up but an improvement nonetheless. My budget is +/- $2000, including install costs. Any suggestions would be greatly appreciated, my goal is low 14 second street car
ALL MOTA.
Old Apr 26, 2004 | 06:36 AM
7thGear's Avatar
Default Re: Budget Buildup any suggestions? (blackout95teg)
scourage the classified forums
make friends at your local scrap yard
Old Apr 26, 2004 | 06:49 AM
Gabe_'s Avatar
Default Re: Budget Buildup any suggestions? (7thGear)
Sell your intake, header, and exhaust, and put that money towards a hytech header/exhaust, and a J's intake.
Old Apr 26, 2004 | 05:44 PM
f22suzuka's Avatar
Default Re: Budget Buildup any suggestions? (Gabe_)
Any other suggestions, I really don't want to spend more money on i/h/e, however possibly a jdm 4-1. Any other suggestions with headwork, higher compression pistons, hybrid set-ups ie. poorman's itr, b20vtec, etc?
Old Apr 26, 2004 | 06:02 PM
7thGear's Avatar
cam + cam gear upgrade?
aftermarket intake manifold
also if you want it to accelerate faster, look into lightned flywheels and things like lightned underdrive pully sets and what not.
Old Apr 26, 2004 | 07:47 PM
importboi22's Avatar
mill the head 25 thou, get some flat valves, then get a better header (hytech, toda or the similar ) test pipe true 2.5 inch exhaust and skunk2 stage 2 cams or the similar and hondata s100...
Old Apr 26, 2004 | 07:51 PM
f22suzuka's Avatar
Default Re: Budget Buildup any suggestions? (importboi22)
I was assembling parts for a turbo kit, will the Hondata s100 with boost option work on a NA car? When you say flat valves? Will S2S2 Valvetrain work? thanks for your input, importboi. What out there is a true 2.5" exhaust?
Old Apr 26, 2004 | 08:21 PM
NR_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackout95teg &raquo;</TD></TR><TR><TD CLASS="quote"> What out there is a true 2.5" exhaust?</TD></TR></TABLE>
Kteller, T1R, custom, im sure theres more. Any 60-60.5 mm exhaust will work, weight reduction will also help ya...i would ditch the 4-2-1 header for sure.
Old Apr 26, 2004 | 08:31 PM
f22suzuka's Avatar
Default Re: Budget Buildup any suggestions? (NR_hatch)
Does anyone know about Hondata I have the S100b for boost, would it be compatible even if Im not boosting?
Old Apr 30, 2004 | 11:08 AM
f22suzuka's Avatar
anymore suggestions for a mildly funded all motor project I have a 1995 B18C now.
Old Apr 30, 2004 | 11:43 AM
TOM J's Avatar
Old Schooler
How much do you want to spend?
Old Apr 30, 2004 | 06:15 PM
7thGear's Avatar
Default Re: Budget Buildup any suggestions? (TOM J)
figure out what OEM parts from what engine go into what engine to make various combo's in RS and compression ratios
save you a shitload of money than buying JE or Eagle or whatever.
Old Apr 30, 2004 | 06:18 PM
7thGear's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOM J &raquo;</TD></TR><TR><TD CLASS="quote">How much do you want to spend?
to answer your question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackout95teg &raquo;</TD></TR><TR><TD CLASS="quote">anymore suggestions for a mildly funded all motor project I have a 1995 B18C now.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackout95teg &raquo;</TD></TR><TR><TD CLASS="quote"> My budget is +/- $2000, including install costs. Any suggestions would be greatly appreciated, my goal is low 14 second street car
ALL MOTA.</TD></TR></TABLE>
i hope i dont get someone like you doing an order if i ever get around to it.
36Chitownrunnin
13
Aug 7, 2008 09:46 PM
accord1101
May 13, 2004 07:38 PM
Si Erik
Jun 18, 2003 08:14 AM
Blue Liquid
Jan 24, 2002 10:56 PM
