16g tdo6h how much can it handle?
Old Apr 26, 2004 | 05:47 AM
B18CRacer's Avatar
Default 18g tdo5h how much can it handle?
i got the 18g tdo5h turbo and I wanted to know how much I can push this?
Modified by B18CRacer at 1:28 PM 4/27/2004
Modified by B18CRacer at 1:29 PM 4/27/2004
Old Apr 26, 2004 | 06:03 AM
TravSi's Avatar
Default Re: 16g tdo6h how much can it handle? (B18CRacer)
there are guys in the dsm world running 11's on that turbo....Its a good turbo, and will make a decent amount of power...Definetly 350ish i would say, my friend runs that turbo on his dsm and he pushes 21-25psi and it pulls strong
Old Apr 26, 2004 | 09:32 PM
B18CRacer's Avatar
Default Re: 16g tdo6h how much can it handle? (TravSi)
what kind of setup did he have? Is it the greddy kit?
Old Apr 27, 2004 | 07:27 AM
kpt4321's Avatar
Are you *sure* it is a TDO6H 16g? If it's a TDO6H, I would be inclinded to think it has an 18g wheel.
Either way, you're talking 34 lb/min maximum flow rating, at the least. That means over 300 whp, no problem.
Old Apr 27, 2004 | 12:29 PM
B18CRacer's Avatar
Default Re: (jz)
yeah you are right tdo5h 18g
Old Apr 27, 2004 | 04:12 PM
kpt4321's Avatar
Wait. I suggested one or the other, not both. TDO5H 18g is also possible though.
The 18g wheel is capable of almost 400 crank horsepower, approximately.
Old Apr 27, 2004 | 07:36 PM
B18CRacer's Avatar
Default Re: (jz)
yes i finally took it off the car and looked at the greddy tag...I can barely read but it said tdo5h 18g. So it possible to push it 400hp?
Old Apr 27, 2004 | 08:58 PM
kpt4321's Avatar
Default Re: (jz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jz &raquo;</TD></TR><TR><TD CLASS="quote">yes it is, i have a tdo5-20g. </TD></TR></TABLE>
TDO5 what, compressor cover or turbine wheel?
Old Apr 27, 2004 | 08:59 PM
kpt4321's Avatar
Default Re: (B18CRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CRacer &raquo;</TD></TR><TR><TD CLASS="quote">yes i finally took it off the car and looked at the greddy tag...I can barely read but it said tdo5h 18g. So it possible to push it 400hp?</TD></TR></TABLE>
Yes. The 18g wheel can flow enough air to make around 400 crank horsepower.
I don't have a compressor map handy, so I'm afraid I can't be any more specific than that.
Old Apr 27, 2004 | 10:31 PM
B18CRacer's Avatar
Default Re: (kpt4321)
thanks kpt4321...what kind of setup would maximumize the effectiveness of this turbo?
Old Apr 28, 2004 | 12:15 AM
Si-Yaaa!'s Avatar
I'm glad you asked this question because I was wondering the same thing. I'll be running my greddy kit with an 84mm b16 block and 9:1 compression. I just wanted to be over 300whp when I'm done. Gotta love A/C.
MR2bl326
Jan 25, 2007 02:37 PM
Liquidgsr
Aug 11, 2006 11:09 PM
impound
Apr 14, 2004 06:05 PM
camocears
Sep 30, 2003 02:41 PM
GreddySi99
Feb 12, 2003 05:50 PM
