B20 rods in a b16!!?
Old Apr 26, 2004 | 04:02 AM
thad
Guest
Posts: n/a
Default B20 rods in a b16!!?
ok so i was on endyn's site lookin at rollerwaves and i noticed that the B16 selection was broken into two parts, B16A(all) and B16A(with B20 connecting rods)
so i did a search and came up with nada, what's this buisness, what are the gains, what displacement could you expect and how does it affect compression?
heres a link.
http://www.theoldone.com/components/pistons/
Old Apr 26, 2004 | 11:50 AM
thad
Guest
Posts: n/a
Default Re: B20 rods in a b16!!? (thad)
up
Old Apr 27, 2004 | 09:09 AM
thad
Guest
Posts: n/a
Old Apr 27, 2004 | 09:57 AM
DonF's Avatar
You need custom pistons with the pin moved up, several people make them.
Old Apr 27, 2004 | 12:57 PM
Rocket's Avatar
Default Re: B20 rods in a b16!!? (DonF)
This moves your power band up in the rpm range so you can run higher speeds in a given gear. I would imagine that a road course with longer straight aways this could be beneficial.
Old Apr 28, 2004 | 06:32 PM
thad
Guest
Posts: n/a
Default Re: B20 rods in a b16!!? (Rocket)
what advantage does it have over a tranny with longer gears?
and would it affect compression or displacement?
Old Apr 28, 2004 | 07:12 PM
fearless_dsm's Avatar
doing that doesnt increase displacment,but can raise compression.It also doesnt make your gears any longer or let you hang on to gears any longer.Its just lets you rev slightly higher do to the better rod to stroke ratio.If you got a tranny with longer gears,youre engine would have a harder time as is pulling through the gears.
Old May 2, 2004 | 08:21 PM
thad
Guest
Posts: n/a
Default Re: B20 rods in a b16!!? (fearless_dsm)
i see, thanx for clarifying, anybody know what the actual stroke would be with this setup
Old Apr 24, 2005 | 03:11 PM
CaptivaBlue's Avatar
I know I'm bumping an old post but it's better than starting a new one, there was very little in the archives regarding this.
I saw this on Endyn's site as well and I had similar questions. Does it only shift the powerband? It won't help create any more power than normal? Or torque due to the longer stroke? Does it require a B20 crank or a B16 crank with just B20 rods and the special pistons made for this app?
Old Apr 24, 2005 | 07:30 PM
Rumblee's Avatar
Default Re: B20 rods in a b16!!? (CaptivaBlue)
It will not affect stroke. It only changes the rod/stroke ratio by using a longer rod with a shorter piston. The idea is that it slows piston speed near tdc allowing it to dwell there a little longer for a better burn at high rpms. I dont know if the b20 rods have different sized rod journals than a b16, but i would think they are the same.
ghost86
Jul 22, 2009 04:22 PM
ef9itb
Jan 15, 2008 06:51 PM
SIC_jdm_da9
Aug 22, 2007 03:55 PM
Zero2Sixty
Nov 2, 2002 03:57 PM
