How DO you install short shifters!!?!??!?! <=======ROOKIE!!
btw, you might wanna have some socket extensions handy. your b-pipe will be in the way. so it's also best to let the car cool down a bit.
here are the steps:
step 1: take your new short shifter.
step 2: Take a look at it.
step 3: Turn it around
step 8: Stick it up your ***.
IN STEPS 4-7 YOU CAN DO WATEVER YOU WANT WITH IT
In your mind you are probably saying "DAMN THATS HELLA EASY" "PIECE OF CAKE"
OK OK OK
Steps
1: jack car up
2: take the rubber peices off your exhaust
3: take your 10mm with ratchet and unscrew the 10mm holding your heatshield (if you still have it)
4: take 12mm and unscrew the two 12's holding up your shift linkage
5: OH YEA I 4GOT GET BACK INSIDE YOUR CAR AND TAKE OFF YOUR SHIFTNOB
6: then pull your shift linkage down
7: start unscrewin it
8: start screwin it
9: back it up
10: screw it back
Steps
1: jack car up
8: start screwin it
9: back it up
10: screw it back
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bretx0r »</TD></TR><TR><TD CLASS="quote">step 1. take it out of packaging
step 2. install
step 3. drive the car</TD></TR></TABLE>
god yes
step 2. install
god yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=745235</TD></TR></TABLE>
Thought that might help someone one day.
88EFhatch
Jun 7, 2005 12:03 AM
