How DO you install short shifters!!?!??!?! <=======ROOKIE!!
Re: How DO you install short shifters!!?!??!?! <=======ROOKIE!! (Ecskater1
can't remember which size.....
10 or 12 mm socket wrench
10 or 12 mm wrench
get under your car
10 or 12 mm wrench
get under your car
btw, you might wanna have some socket extensions handy. your b-pipe will be in the way. so it's also best to let the car cool down a bit.
Its also good to have your car atleast 18" off the ground so you have clearance to get the old one out and the new one in.
here are the steps:
step 1: take your new short shifter.
step 2: Take a look at it.
step 3: Turn it around
step 8: Stick it up your ***.
IN STEPS 4-7 YOU CAN DO WATEVER YOU WANT WITH IT
In your mind you are probably saying "DAMN THATS HELLA EASY" "PIECE OF CAKE"
OK OK OK
Steps
1: jack car up
2: take the rubber peices off your exhaust
3: take your 10mm with ratchet and unscrew the 10mm holding your heatshield (if you still have it)
4: take 12mm and unscrew the two 12's holding up your shift linkage
5: OH YEA I 4GOT GET BACK INSIDE YOUR CAR AND TAKE OFF YOUR SHIFTNOB
6: then pull your shift linkage down
7: start unscrewin it
8: start screwin it
9: back it up
10: screw it back
Steps
1: jack car up
8: start screwin it
9: back it up
10: screw it back
OG triple OG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bretx0r »</TD></TR><TR><TD CLASS="quote">step 1. take it out of packaging
step 2. install
step 3. drive the car</TD></TR></TABLE>
god yes
step 2. install
god yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=745235</TD></TR></TABLE>
Thought that might help someone one day.
88EFhatch
06-07-2005 12:03 AM
