LS owners, help? look at my engine
My teg works fine, I drive it a few times a week. No leaks on the ground but when I popped the hood today, just curious, I found oil stains(see pic) only on the left side. I don't know where it's coming from. I checked the ground each day and I don't see leaks, must have been VERY slow leaks.. . where's the problem? what is wrong?
[Modified by acuraLSSE95, 2:51 AM 11/1/2001]
[Modified by acuraLSSE95, 2:52 AM 11/1/2001]
[Modified by acuraLSSE95, 3:07 AM 11/1/2001]
[Modified by acuraLSSE95, 3:08 AM 11/1/2001]
hmm that looks like its comming either from the crank seal (between the tranny and the block) or even from the headgasket, but most likely the crank seal. I would take it to someone to have it checked out.
you gotta get a better pic, I cant tell if its comming from the cam seal either or not
http://www.geocities.com/acuralsse95/engine5.jpg
remove the http, or jsut cut and paste and it will work.
[Modified by 97blackteg, 9:57 PM 10/31/2001]
no, but id check your oil to make sure your not low.....but just buy an STR plug..its like 30 bucks and install it. Acura could fix it but it would probably be more money than that in my opionion
ok, im pretty sure its a the camshaft seal....but just clean the area up all nice..and a day later look at it and take more pics...but its probably the cam seal...i currently have the same problem but not nearly as bad as yours...they have been known to break down over time.
I went to Acura today, got things fixed. this is what they did:
Replaced OIL pan Gasket and Rubber (225.00)
Filter, oil (7.50)
Washer,14mm(.33)
5 oil 5w30(6.50)
Gasket, OIL pan(22.85)
Rubber(5.15)
I extended warranty paid 270, so I paid like 20 bucks.
Filter, oil (7.50)
Washer,14mm(.33)
5 oil 5w30(6.50)
Rubber(5.15)
i dont think taht was your oil pan gasket but hey, every dealer has to make money some how....you will find out soon enough if it was, keep an eye on that cam seal though.
