Valve Cover Bolts
Old Apr 25, 2004 | 08:30 PM
islander27's Avatar
Default Valve Cover Bolts
I just finish painting my valve cover...when i was screwing back in the bolt....i accidentally over tightened the one of the bolts....and i heard something snap...and the bolt was loose all of sudden...will the valve cover still hold down? any oil leaks? its the lower right bolt.....
Old Apr 25, 2004 | 08:32 PM
SOHC_MShue's Avatar
Default Re: Valve Cover Bolts (islander27)
i've had this happen twice. You will more than likely have oil leaking out. It leaked out all over the place on mine when I drove to honda to get a new bolt. I would recommend replacing it as soon as possible. You will probably have to take the valvecover back off and get the remainder of the bolt that is stuck in your head out. I had to use a drill and an ez out to get the thing out. It sucked
Old Apr 25, 2004 | 08:33 PM
ABK's Avatar
ABK
what head is it?
Old Apr 25, 2004 | 08:34 PM
rxse7n
Guest
Posts: n/a
Yup, bad bolt to overtighten. Try driving around the block a couple times and see how much oil you are losing. If you do have to drive it to honda to pick up a new bolt, take some extra oil with you just in case.
islander27's Avatar
Default Re: Valve Cover Bolts (ABK)
i have a d16z6 from a 95 civic ex coupe
Old Apr 25, 2004 | 09:15 PM
Ignitecivic's Avatar
it happen to my d16z6 before too, but no leaks.
Old Apr 25, 2004 | 09:26 PM
islander27's Avatar
Default Re: Valve Cover Bolts (Ignitecivic)
oh ok thanks for all the help...i'll keep an eye if there any oil leaks though
Old Apr 25, 2004 | 09:28 PM
boostng r's Avatar
a
**** put duck tap over it and then go to honda
Old Apr 25, 2004 | 09:30 PM
rxse7n
Guest
Posts: n/a
Duck tap? Do you tap ducks often?
Old Apr 25, 2004 | 09:33 PM
BoostinEJ1's Avatar
Default Re: (rxse7n)
My friend did this to my motor when we were switching up valve covers, we got his father to take a tiny as drill bit to it and slowly backed it out. Was not fun at all but luckly no damage, not that I have been able to tell and this was months ago.
p.bass
14
Jun 30, 2014 08:28 PM
batallic
11
May 27, 2008 03:07 PM
k_lude
Jan 9, 2007 06:48 PM
methos713
15
Feb 18, 2005 12:13 AM
LoudAccord
Jan 9, 2003 10:43 AM
