Heat wrapping stainless steel headers bad?
Old Apr 25, 2004 | 08:25 PM
Stock@$$GSR's Avatar
Default Heat wrapping stainless steel headers bad?
so people say that heat wrapping headers is bad, because it promotes rust and cracks, but what if you wrap stainless steel headers? Stainless steel isn't supposed to rust, so do you guys think it'll be alright to do it? Also, how does wrapping a header cause it to crack? Just trying to understand TIA
Old Apr 25, 2004 | 08:44 PM
KTeller8's Avatar
Default Re: Heat wrapping stainless steel headers bad? (Stock@$$GSR)
some ppl said that it has to do with the heat not being able to be released
Kendall's Avatar
Wrapping stainless steel headers
Wrapping ceramic coated headers
You shouldn't have any issues wrapping a stainless header. It should help it if anything.
Old Apr 25, 2004 | 10:24 PM
Default Re: Heat wrapping stainless steel headers bad? (KTeller8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote">some ppl said that it has to do with the heat not being able to be released</TD></TR></TABLE>
so does the increased heat make it more brittle which equates to a cracked header?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">You shouldn't have any issues wrapping a stainless header.</TD></TR></TABLE>
I'm hoping this is the case, so I don't have to send my header to get professionally coated (i'm a poor **** ) Anyone and everyone who has actual experience with wrapping stainless headers wanna also chime in to throw in your 2 cents? Thanks guys
Old Apr 25, 2004 | 11:58 PM
Rob Dizzle's Avatar
look into why people do it in the first place
its usually to contain heat in the header and not have the heat go into the engine bay
what header do you have?
over time moisture can get stuck in the header wrap then detoriate the header outside.
if you take off the wrap then the header will look like hell
i vote for getting it coated
Old Apr 26, 2004 | 10:18 AM
Default Re: Heat wrapping stainless steel headers bad? (Bob-DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">look into why people do it in the first place
what header do you have?</TD></TR></TABLE>
I'm ordering an AN-R, and I'm trying to figure out exactly how I wanna order it. I want to get the stainless steel version, because they say that it's stronger than the normal metal that they normally use, and well, it's supposed to not rust. Getting the coating option on top of the Stainless option, and that's just gonna break my wallet (into the $1000 range). I figure the coating does 2 things... it keeps heat in and it protects the metal from rusting. Since I'm already getting the Stainless option, I don't have to worry about rusting. This is why I'm trying to explore other "healthy" options as to what I can do about keeping the heat in and that's why I'm specifically asking if wrapping Stainless is ok or not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">over time moisture can get stuck in the header wrap then detoriate the header outside.
See, this is exactly what I'm trying to figure out... is wrap bad for Stainless becuase it makes it look like hell, or does it actually structurally damage the metal so it's more prone to cracks and deterioration? i don't care about looks so much, so pitting and staining doesn't bother me as much.
Old Apr 26, 2004 | 10:29 AM
Rob Dizzle's Avatar
search header wrap on archived info
i saw over 40 threads already describing it
did you ask an-r about what they recomend?
you can get a bisi header for under 900 with a coating. but there is a back order right now
thinking of pricing reminds me of how good a deal the dc or jdm 4-1 header is...
https://honda-tech.com/zerothread?id=509047
i would just save the money for a good coating
hpc coatings reduce engine bay temps by as much as 40% from coating a header
thats good enough for me
Old Apr 26, 2004 | 03:33 PM
DefiantGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">search header wrap on archived info
thats good enough for me</TD></TR></TABLE>
damn, any more information on this? link?
Old Apr 26, 2004 | 10:41 PM
so if I go with a good coating like hpc or jethot, should I just get the regular steel option and skip the stainless? the coating should protect the header from rust, right?
Old Apr 27, 2004 | 12:22 AM
KTeller8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stock@$$GSR &raquo;</TD></TR><TR><TD CLASS="quote">so if I go with a good coating like hpc or jethot, should I just get the regular steel option and skip the stainless? the coating should protect the header from rust, right?</TD></TR></TABLE>
call jethot and ask them, what they think..
they would know what and how their coating works on both versions:
Old Apr 27, 2004 | 12:31 AM
chasingamy's Avatar
I have a RSR stainless steel header which is JASMA approved... it still rust....
Old Apr 27, 2004 | 08:25 AM
ce's Avatar
ce
I had my DC JDM wrapped and drove around with it for over half a year before I sold it. No problems whatsoever. It did look a bit crappy after the guy who bought it took it off but no damage to the metal itself. I will also wrap my new Toda header in the near future. It did drop engine temp a couple of degrees ( measured with hondata datalogger) so that's good enough for me :-)
Old Apr 27, 2004 | 08:52 AM
Rob Dizzle's Avatar
Default Re: Heat wrapping stainless steel headers bad? (DefiantGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR &raquo;</TD></TR><TR><TD CLASS="quote">damn, any more information on this? link?</TD></TR></TABLE>
list of some of the major coating companys:
http://www.honda-central.com/r...at=35
http://www.hpcoatings.com/
hpc doesnt copy anyone (unlike many others)
they do alot of r&d, do alot of work for nasa and armed forces
great product
djviet2000
May 13, 2007 08:46 PM
JMU R1
Jan 15, 2007 07:21 PM
b18c5-specR
Nov 9, 2006 06:37 PM
g3teg97
Jul 3, 2005 09:24 PM
93formula
Mar 31, 2005 08:55 AM
