F@&kin crank bolt!!!???
Old Apr 25, 2004 | 07:23 PM
super trucker's Avatar
Default F@&kin crank bolt!!!???
I've got my stock D16 on the ground, clutch is off and I need to take the crank pulley off to replace my water pump/timing belt. Problem is, I put my impact on the crank bolt and it wouldn't budge!!! I've never encountered a crank bolt this stubborn in my life (I used to wrench GM's for a living)!!!!!! This is no GM either, with lots of big holes in the flywheel to shove something into so that it doesn't turn when I use a persuasion bar on the crank bolt. Anyone else ever have this problem, or am I just an idiot and this honda is kicking my A$$!!
thanks in advance,
Neil
Old Apr 25, 2004 | 07:36 PM
SunkistRex's Avatar
Default Re: F@&kin crank bolt!!!??? (super trucker)
haha i had the same problem, i sprayed PB Buster (the whole can lol) onto that bitch and after 10 min of impactin it came loose, i stuck a 3/8 extention in the hole and went at it..
Old Apr 25, 2004 | 07:48 PM
kranked91dx's Avatar
Hell no damn hole trough the flywheel !!!
you can put a pri bar against the dowel pin and the toot of the flywheel, and pry the **** out of the pulley bolt with a 4 foot extension on the breacker bar....
Yup Yup Yup, it work, it's gettho but it's actually work's
Kranked
Old Apr 25, 2004 | 08:09 PM
Donkey85's Avatar
Default Re: F@&kin crank bolt!!!??? (kranked91dx)
nope ur not the only one that mother takes a hell of a put of tuggin to break it loose a 4-5ft breaker bar is your friend good luck
Old Apr 25, 2004 | 08:38 PM
fourthgenhatchB17's Avatar
Default Re: F@&kin crank bolt!!!??? (Donkey85)
Turn the psi up if u havent done so already.
Old Apr 26, 2004 | 12:35 AM
MR5sARECOOL's Avatar
Default Re: F@&kin crank bolt!!!??? (fourthgenhatchB17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">Turn the psi up if u havent done so already.</TD></TR></TABLE>
and use the shortest extension, or none at all.
Old Apr 26, 2004 | 02:55 AM
FourthGenHatch's Avatar
Old Apr 26, 2004 | 05:11 AM
Lo-Buck EF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kranked91dx &raquo;</TD></TR><TR><TD CLASS="quote">Hell no damn hole trough the flywheel !!!
Kranked</TD></TR></TABLE>
thats what worked for the one i did with the engine out of the car. put my foot on the valve cover to keep the whole engine from rolling around and pulled with a big braker bar and 4' pipe. came right off. doing it while in the car tool a little more creativeness....
Old Apr 26, 2004 | 08:25 AM
4potnick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super trucker &raquo;</TD></TR><TR><TD CLASS="quote">I've got my stock D16 on the ground, clutch is off and I need to take the crank pulley off to replace my water pump/timing belt. Problem is, I put my impact on the crank bolt and it wouldn't budge!!! I've never encountered a crank bolt this stubborn in my life (I used to wrench GM's for a living)!!!!!! This is no GM either, with lots of big holes in the flywheel to shove something into so that it doesn't turn when I use a persuasion bar on the crank bolt. Anyone else ever have this problem, or am I just an idiot and this honda is kicking my A$$!!
thanks in advance,
Neil</TD></TR></TABLE>I am in the middle of this problem in my girlfriends 93 civic. Yesterday I tried to do a timing belt and water pump. At first I had her try to crack the bolt with 3 foot breaker bar and 4 foot cheater bar as I was under the car holding the flywheel secure. Come to find out she was not strong enough. Insert my friend, so he starts out by breaking my 17mm 6pt craftsman socket. So I say okay no problem I have a 12pt. 17mm(craftsman) the 6pt maust of been weak. Nope broke that 17mm also. At least you can just swap them at sears. Now I have 17mm impact socket to try out. just waiting for a friend to come over so I can finish my(3 hour ) job.
Old Apr 26, 2004 | 08:30 AM
spaceman's Avatar
Default Re: F@&kin crank bolt!!!??? (4potnick)
ya dood i just got done doing that job..you need atleast a half inch extension and a friend or bro that knows what to do...good luck
Old Apr 26, 2004 | 08:32 AM
Lo-Buck EF's Avatar
LOL, my 1.5 hour engine mound change turned into a 4 hour mission. gotta love crank bolts.
Old Apr 26, 2004 | 09:22 AM
goforbroke's Avatar
MEAT PATTY
Default Re: F@&kin crank bolt!!!??? (Lo-Buck EF)
Yeah they are a real B***** to change. I have to change mind this week. I was reading the specs on the torque tightest when putting it back on it says 145 ft lbs so they are going to be tight. Also try to use the shortest extension possible so you don't lose any torque or try not to use any extension if possible. Even though a impact gun is strong as sh** they usually won't break the bolt lose. Breaker bar is your friend
Old Apr 26, 2004 | 05:52 PM
mrtoastyjr's Avatar
Default Re: F@&kin crank bolt!!!??? (goforbroke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke &raquo;</TD></TR><TR><TD CLASS="quote">Even though a impact gun is strong as sh** they usually won't break the bolt lose. </TD></TR></TABLE>
unless you get a 1 inch drive, 400 ft/lb impact gun, you know, they look like those guns that rambo used
Old Apr 26, 2004 | 06:30 PM
ninjaMONKEY
Guest
Posts: n/a
got any fat friends to stand on the breaker bar??
Old Apr 26, 2004 | 07:01 PM
Lo-Buck EF's Avatar
Default Re: F@&kin crank bolt!!!??? (ninjaMONKEY)
http://www.harborfreight.com/c...=2623
i think this would do it
Old Apr 26, 2004 | 07:03 PM
Mr_CRX's Avatar
I used an impact gun to get mine off. Wasnt one of those high torque 1" drives or anything, just a 1/2" one from my brother's house. It took some time, but after i let it beat on the bolt for a minute or two and then let the compressor refill itself, it eventually came off. I had to max out the compressor at 150psi though and it still took a while.
Old Apr 26, 2004 | 07:11 PM
Kasper.'s Avatar
Default Re: F@&kin crank bolt!!!??? (Mr_CRX)
Get a propane torch.
heat it up till its glowing red.
Id put my 2135 IR gun on it like the one showed. You use whatever tools you have left.
get the right tool to hold the flywheel.
and let it rip.
then drink a beer.
Old Apr 26, 2004 | 07:13 PM
johnjw's Avatar
here's what I do, and it works everytime no impact tools needed
If the engine is out of the car its even easier.
with the clutch cover off.....find a bracket( I used the intake man bracket) and bolt it too the block close to the flywheel and then on the other side of the bracket bolt it to the flywheel....now the bolt will stay stationary while you use the biggest breaker bar you have.....works for me everytime even if the engine is in the car, just take off the black cover thats on the bottome of the transmission and do the same..
good luck hope that helps
Old Apr 26, 2004 | 07:17 PM
Lo-Buck EF's Avatar
Default Re: F@&kin crank bolt!!!??? (Kasper-EF8)
yea, it realy shouldnt be hard when its out of the car. the d15 i pulled appart had 170k on it and that bold came out with a braker bar+ 4' pipe. i put 2 flywheel bolts in and one trans bolt. then put a jack handle between them and that held the crank from turning. then put one foot ont he vlave cover and pulled the 4' pipe toward me till the bolt loosened.
-spenc
Old Apr 28, 2004 | 10:24 AM
VitaminD's Avatar
this is what worked for me. I took a section of nylon rope, from a boat anchor. And stay with me here... thread it into the cylinder as much as you can, crank that thing over and compress the rope. It wont damage the cylinder or piston. just be sure to re-torque the head bolt afterwards. This is only good in a time of dire need.
D
Old Apr 28, 2004 | 12:33 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: F@&kin crank bolt!!!??? (VitaminD)
once i had to use a 3/4"er from work.. that socket barley fit in that big *** hole. 1/2 drive wasn't cutting it, and that was at 140PSI with mad volume.
Old Apr 29, 2004 | 06:19 AM
1SIKCRX's Avatar
Default Re: F@&kin crank bolt!!!??? (Built B16A)
here's what i do. i take an old peice of a crank pulley belt(i have one cut to length here). and put it around the crank pulley. i then put on my chain wrench. then i *try* my air gun first. but that hardly works to get it off!! so i use a long breaker bar with a 2-3 feet of pipe over it.
Old Apr 29, 2004 | 10:10 AM
mr. carpenter's Avatar
Default Re: F@&kin crank bolt!!!??? (1SIKCRX)
easiest with motor out of car. take tranny off and leave flywheel on. stick a screwdriver through flywheel and wedge it to hold motor still. put breaker bar on bolt. stand on breaker bar with a good weight. should break free. youcan also stand motor against wall and pull up on breaker. i find it easier to put my hands on valve cover to steady motor then put my weight on breaker
Old Apr 30, 2004 | 06:29 PM
goforbroke's Avatar
MEAT PATTY
Default Re: F@&kin crank bolt!!!??? (mr. carpenter)
Ok, now I need help lol I just got done doing putting my water pump and timing belt on and now I need to find out a way to tighten the crank pulley bolt. And I don't have that special tool so what else can I do to make it work. The motor is still in the car by the way.
Old Apr 30, 2004 | 08:03 PM
Thanks for all the tips. Maybe if I put them all together, I won't even break a sweat!!!!!! As for the nylon rope trick, I've done that on V8's before, nice tip. I only get weekends to work on it because of my job, I soaked the hell out of it last weekend with Knock-er-loose, I'm hoping it's soaked in so tomorrow I can put some heat on it, and light er up with the impact. Get this, air compressor crapped out on me, won't even turn the impact.....so, guess I'll have to use the Kenworth. The semi puts out about 120 psi. I love trucks. Again, thanks for all the tips. As far as tightening the crank pulley, would it work to just try putting it in gear? I know I made that work with a V8 once. Just a thought. I don't know much about four-poppers, but I'm trying to learn.
