AEBS Intake Manifold for 2000 B16
Old Apr 25, 2004 | 06:59 PM
See Are X's Avatar
Default AEBS Intake Manifold for 2000 B16
i tried to search, but didnt get the info i was looking for...
Will the manifold bolt directly onto my 2000 B16 with the B16 fuel rail, TB, and IACV? or do I need to get something else? Cause a friend of mine bought a AEBS manifold for a 1st gen B16, the fuel rail didnt fit right, and the TB didnt either....the TB bolted up to the manifold, but the bracket for the throttle cable was in the way
Old Apr 25, 2004 | 08:07 PM
forced00si's Avatar
Default Re: AEBS Intake Manifold for 2000 B16 (See Are X)
I pit one on a 00 civic si. the only thing that didnt bolt up is that big bracket on the bottom to the motor . possibly because of hondata gasket.
Old Apr 25, 2004 | 08:45 PM
KTeller8's Avatar
Default Re: AEBS Intake Manifold for 2000 B16 (forced00si)
not 100% sure.. check aebsracing.com
Old Apr 26, 2004 | 04:54 PM
See Are X's Avatar
Default Re: AEBS Intake Manifold for 2000 B16 (KTeller8)
anyone else?
Old Apr 26, 2004 | 07:22 PM
ArinX's Avatar
i used a 2000 b16 head on ls/vtec and had no problems, b16 throttle body bolted up and so did the fuel rail.... you just have to remove those black plastic spacers.
Old Apr 26, 2004 | 07:52 PM
Lysawy's Avatar
Default Re: AEBS Intake Manifold for 2000 B16 (ArinX)
Same here bottom bracket had to be cut in order to fit...
Old Jun 16, 2004 | 09:56 PM
eRaceParts_com's Avatar
The AEBS manifold was designed for the US 93-00 B16. That's why the 1st gen pre-OBD B16 has trouble. The DelSol and Civic B16s should have no real obstacles like the old B16.
Old Nov 2, 2004 | 11:50 AM
allmotorteg_96's Avatar
Default Re: AEBS Intake Manifold for 2000 B16 (eRaceParts_com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eRaceParts_com &raquo;</TD></TR><TR><TD CLASS="quote">The AEBS manifold was designed for the US 93-00 B16. That's why the 1st gen pre-OBD B16 has trouble. The DelSol and Civic B16s should have no real obstacles like the old B16. </TD></TR></TABLE>
what trouble will i run in to if i have a 90 b16 head on my 96 ls using the aebs
Old Dec 28, 2004 | 09:24 PM
teg4life's Avatar
Default Re: AEBS Intake Manifold for 2000 B16 (allmotorteg_96)
yes what trouble could occur??
Old Dec 28, 2004 | 10:07 PM
CRVTEC0WNZJ00's Avatar
I have AEBS IM, fuel rail, stock TB, everything bolted up and works fine together.
Old Dec 29, 2004 | 12:41 AM
KTeller8's Avatar
since this was dug up.. this is the exact answer to this thread!
Old Dec 29, 2004 | 08:12 AM
johnzm's Avatar
i mounted a AEBS mani on my 1st gen manifold.
the TB i used a ITR one so no issues there, the fuel rail is a different story. on the 1st gen the FPR will hit the IAT sensor on that manifold, so to do it right u gotta get a different rail, that located the FPR at the very end. and then get the spacers setup for it.
Old Dec 29, 2004 | 08:19 AM
johnzm's Avatar
Default Re: AEBS Intake Manifold for 2000 B16 (johnzm)
a few pics for comparison...
this is the correct fuel rail on this one, notice the FPR at the end...
ITR TB Vs 1st gen b16
i dont see any difference really in bolt locations..
if u look at the FPR in this pic, it would obviously be blocking the IAT on the ITR and AEBS manifolds.
other than this maybe a little trickery for vaccum routing on a EF (MAP is mounted on the firewall) and everything is easy!
Old Dec 29, 2004 | 08:26 AM
DavidT or VajT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm &raquo;</TD></TR><TR><TD CLASS="quote">i mounted a AEBS mani on my 1st gen manifold.
A 2nd gen B16 fuel rail will work fine...
Old Dec 29, 2004 | 08:39 AM
johnzm's Avatar
Default Re: AEBS Intake Manifold for 2000 B16 (DavidT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavidT &raquo;</TD></TR><TR><TD CLASS="quote">
A 2nd gen B16 fuel rail will work fine...</TD></TR></TABLE>
i actually used a ITR fuel rail, but whatever. any fuel rail other than obd0 will work
Old Dec 29, 2004 | 08:43 AM
RobbieG35's Avatar
12 Years Strong
on the 99-00 Si the IAT sensor goes into the intake, do you have to move it to the IM runner?
D17Dyl
K Series
Oct 13, 2018 03:17 AM
sejthewedge
Apr 6, 2009 07:41 PM
turbo sol
Nov 5, 2008 06:22 PM
HamiltonRex
Oct 27, 2004 06:11 AM
mikwon
Mar 11, 2004 01:04 PM
