dpfi to mpfi Distributor connector problem??
yes i have it shows it but just as a.b,c,d,e,f,g with arrows to each an tells you put volt meter on a,d to check sensor an bla bla bla but does not say colors or anything
DX should have 5 pins. Si has 7. Only ones you will be confused about is a white pair, one of them is the o2 sensor, just do a read out on it to find out which one it is. The other two you are adding are self explanatory.
where can i get a read out of the wires, about half of the wires are the same color as the dx
Modified by sodacan33 at 3:11 PM 4/26/2004
REALLY SIMPLE!
Your new SI distributor has all the pinouts on the plug that comes with it!
Just a mirror image of what your harness plug should look like.
The only confusion could be with the two white wires, and here is the directions:
DX distro plug:
OWO
OOX
(X= empty pin). The white wire that is marked with "W" on that diagram goes here:
SI: distro plug:
_X_
0W0
0O0
_0_
The other white wire goes to the other spot.
Are the pictures readable or are they too abstract? You should be able to understand them if you look at them and at the distro plugs.
DX distro plug:
OWO
OOX
SI: distro plug:
_X_
0W0
0O0
_0_
xci_ed6
Dec 23, 2002 02:40 PM
