please help
Old Apr 25, 2004 | 05:21 PM
91LSVTEC HB's Avatar
Default please help
i just swap in a fully built LS VTEC into my 91 si hatch and it died on me on the freeway at 65. it bogged down like i released the gas but it would bog down more when i gave it more gas. it backfires when i try to start it. some say its the fuel filter is clogged. number 2and 3 plugges are normal with fuel smell but 1 and 4 are not. anyone know wat is causing this. the motor has 1400 miles on her, built for drag racing.
Old Apr 25, 2004 | 05:25 PM
Default Re: please help (91LSVTECH)
my computer is a PR3 non vtec, i am waiting for the right computer, PR3 w/ vtec
Old Apr 25, 2004 | 05:26 PM
FourthGenHatch's Avatar
If you turn the key does it start but die right away?
Old Apr 25, 2004 | 05:27 PM
Default Re: please help (FourthGenHatch)
no it cranks and backfires
Old Apr 25, 2004 | 05:29 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91LSVTECH &raquo;</TD></TR><TR><TD CLASS="quote">no it cranks and backfires</TD></TR></TABLE>
Timing, set cams to zero. Check cap and rotor. Set distributor timing to stock. Whats fuel PSI?
Old Apr 25, 2004 | 05:34 PM
Default Re: please help (LSVTEC 91 Civic)
cap and rotor r good, tried distributor timing but nothing, timing is off by like a 32nd not sure about fuel psi yet
Banned
Are cams set to zero?
Old Apr 25, 2004 | 05:36 PM
cams r good
Old Apr 25, 2004 | 05:38 PM
Backfiring sounds like a timing issue.
Old Apr 25, 2004 | 06:05 PM
Banned
It does.... what about the total timing? Is the dizzy set to stock point?
aztec_warrior
Aug 6, 2010 09:58 AM
Wazup
Apr 5, 2007 06:57 AM
fatexpletive
Jun 6, 2006 02:19 PM
ThisLittleSleepeR
21
May 20, 2005 06:55 PM
