B20b swap in del question
Old Apr 25, 2004 | 04:46 PM
brizjuan's Avatar
Default B20b swap in del question
I have a B20b for my 95 del sol si... What parts do I need off of an LS motor so that I can run an OBD1 LS ecu. If i run the obd1 LS ecu can I use my stock single cam wiring harness since it is also obd1?
Old May 1, 2004 | 02:50 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: B20b swap in del question (brizjuan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brizjuan &raquo;</TD></TR><TR><TD CLASS="quote">I have a B20b for my 95 del sol si... What parts do I need off of an LS motor so that I can run an OBD1 LS ecu. If i run the obd1 LS ecu can I use my stock single cam wiring harness since it is also obd1? </TD></TR></TABLE>
Pretty much all you need is a OBD I distributor (or rewire your B20 unit), throttle cable, motor mounts, flywheel and the intake manifold off from an LS ....I am sure you dont want that manifold that came with the B20 because it wont clear your hood!!! You can use your stock wiring harness but just make sure you lengthen your O2 sensor wires..... considering Civics (d series) have the O2 on the header instead of on the bottom downpipe/catalytic converter (OBD II). When lengthening the O2 wires do not cut both the black wires at the same time because each of them go to a specific location (one is to 12v ACC **dead-end plug at shock tower on driver side** and the other goes directly to the ECU)....
integra3586
Sep 21, 2009 02:08 PM
DuVaL rAcEr
May 5, 2008 08:37 PM
Jose-aka-Pedro
Jun 30, 2007 12:56 AM
KaBooM
Oct 8, 2003 06:19 PM
