Under/oversteer + ride height ?
Hiya guys !
1st and for most, no, my car haven't been corner weighten yet. Later in the summer it will.
I just wanted to know if ride height front/rear could possibly affect under/oversteer.
If so, would a "higher" back increase oversteer a bit ?
Thanks for helping me to figure it out.
From my understanding. I higher front to back ratio will help with braking and turn in but will add push to your exit. The opposite is true for highter back to front and you should exhibit a shight oversteer.
Higher front = more understeer. Weight biases toward the rear (a bit).
Lower front = more oversteer. Weight biases toward the front (a bit).
To see it applied in real life, get your hands on a copy of Option2 video #31. They do a whole segment with an EG6 playing w/ weight bias and how it results in oversteer/understeer. It's pretty cool.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gamby »</TD></TR><TR><TD CLASS="quote">
Any luck that you can hook me up for this file ?
thanks for answers btw.
</TD></TR></TABLE>Any luck that you can hook me up for this file ?
Kinda how I adjusted my setup. I just made small adjustments til I found a nice spot where it was pretty neutral. My girlfriend drives the car also and was never very good with oversteer(don't tell her I told you). I'm actualy very happy with the outcome. I have a very neutral handling car that I could let anyone drive and they would enjoy.
Although I got my best times and won my class more when it was setup to oversteer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboman »</TD></TR><TR><TD CLASS="quote">Kinda how I adjusted my setup. I just made small adjustments til I found a nice spot where it was pretty neutral.
Although I got my best times and won my class more when it was setup to oversteer. </TD></TR></TABLE>
only coilovers ? what's the full set up ?
n-c
Oct 18, 2005 08:30 AM
LX4CYL
Mar 28, 2004 09:20 AM
