99-00 Si rear sway on 1992 Si hatch?
Will the rear swaybar from a 1999 or 2000 Si fit on a 5G hatch? Assuming:
a. I have GS-R rear LCA's.
b. The Si rear swaybar will come with Si endlinks.
I tried to search but it does not index words with 2 or fewer letters so it was hard to get definitive information.
Thanks!
Thanks!
I believe you would have to use the GSR or EG endlinks because of the way the bar attaches to the LCA. I had a GSR sway bar that i was going to install on my EK but I found out the way they bolt to the LCA is different. And since the EG and GSR use the same LCA's I am inclined to beleive that the endlink you would have to use would be from a GSR.
But you can always sell the SI endlinks on here for more than the GSR endlinks cost new.
Hope this helps.
Hope this helps.
JDMhatchback20
Feb 6, 2005 06:47 PM
Synthesis
Mar 24, 2003 02:04 PM
