Maint Light blinking on 6th gen
What do you mean? Is it the check engine light? You can read the code by the service connector. It is located under the glove compartment. I think it is Orange with two wires on it. Put a paper clip in it and turn the key to the second click. The light should flash. When the light stays on for 1 second and goes off that is 10 whaen it flashes quick it is 1. It will read it out twice.
Jason
Jason
Try SEARCHING for maintenance light or just read your manual.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Caveman74 »</TD></TR><TR><TD CLASS="quote">I need to know how to reset the Maint Light. It is blinking at car start up. Thanks</TD></TR></TABLE>
Turn the car off. Hold the reset button on the cluster cover and turn the key to the on position. Wait till the light goes off and then you are done.
nspec_Cd5
Jan 17, 2008 06:06 AM
ROB8387
Dec 16, 2006 02:00 PM
