maint. req. light blinking. 03 LX 4dr
after turning the motor on, the maintenance required light flashes a few times and then shuts off.
Haven't had time to look into it, but it started doing it recently.
just wanted to get a quick response from here.
Thanks
Thanks
Re: maint. req. light blinking. 03 LX 4dr (nspec_Cd5)
milage timed light every 7.5K miles it will come on to remind you to do the maint check on the car
to reset
press and hold odo reset button
turn car on
continue to hold odo reset for 10 seconds
release
to reset
turn car on
release
Re: maint. req. light blinking. 03 LX 4dr (YeuEmMaiMai)
done that already. but its not working
the light is not ON, it just flashes about 7-8 times when i turn the car ON, then the light goes off.
You have to do it before the car starts, otherwise it won't matter, I forget the combination, but what YeuMaiMai said makes sense.
Re: maint. req. light blinking. 03 LX 4dr (msedacca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msedacca »</TD></TR><TR><TD CLASS="quote">You have to do it before the car starts, otherwise it won't matter, I forget the combination, but what YeuMaiMai said makes sense.</TD></TR></TABLE>
not to offend u, but like i said, i've already tried that before.
it doesn't look like its just a maintenance required light for an oil change.
I'm experiencing the same thing. The dealer says it's for brake/steering/coolant fluid service. Each cost app $200. I'm debating whether it's necessary. The light starts with blinking...then later on...after some miles...can't remember exactly how many miles...at the next stage the light will stay on all the time.
Re: maint. req. light blinking. 03 LX 4dr (bc3m)
ONE MORE TIME. Hold the odometer button down (key in off position) with your left hand, continue to hold the button down while you turn the key on (no need to start it) hold the button down til the light goes out. My car has 50k miles, so I've done this a number of times. It works if you do it right. Your owner's manual should also have the directions.
Re: (macdriver)
It shouldnt matter what the service is, its just an idiot light for teling you its time for a scheduled maintenance and shoud be able to be reset. Its really an annoying light !
ROB8387
12-16-2006 02:00 PM
