Anyone remove the AC in there ITR ???
Old Oct 31, 2001 | 03:09 PM
NeXtLeVeL_TyPe_R's Avatar
Default Anyone remove the AC in there ITR ???
I am looking to remove the AC in my 2001 Type R
Has anyone ever done this before?
Help and advice appericated !!
Is there a page or two in the manual maybe someone can email or fax me i would really really appericate !!!
Old Oct 31, 2001 | 03:15 PM
Chris's Avatar
Default Re: Anyone remove the AC in there ITR ??? (NeXtLeVeL_TyPe_R)
Go to Acura and ask for the ADD AC instructions for 98 TypeR and follow them backwards. Have it discharged proffesionally.
Old Oct 31, 2001 | 03:24 PM
Default Re: Anyone remove the AC in there ITR ??? (Chris)
Thanks Will do
Old Oct 31, 2001 | 03:30 PM
sackdz's Avatar
Why have it discharged professionally? Why not just crack them lines open?
[Modified by sackdz, 7:31 PM 10/31/2001]
Old Oct 31, 2001 | 03:34 PM
Default Re: Anyone remove the AC in there ITR ??? (sackdz)
thats what i'm sayin
ill just turn my head and close my eyes
Old Oct 31, 2001 | 03:35 PM
davidnyc's Avatar
The refrigerant is toxic.
norice's Avatar
No AC in NYC summers? Youy are going to regret doing this, particularly when it comes time to sell. AC weighs 40 lbs in a Type-R; spare tire and jack are 30 lbs.
Unless it is a track-only car, removing AC is a lot of work for a tiny amount of gain.
Old Oct 31, 2001 | 03:39 PM
ThePunk's Avatar
Default Re: Anyone remove the AC in there ITR ??? (norice)
Dumping refrigerant into the athmosphere is very bad. Not to mention dangerous to YOU.
Please do you part and be responsible. If you can't afford to have the refrigerant professionally reclaimed, you can't afford to remove your AC.
Old Oct 31, 2001 | 04:10 PM
SleepyR's Avatar
New User
I'm still trying to debate whether I should remove my a/c and get the mugen CAI, but yeah get it done professionally
Old Oct 31, 2001 | 04:46 PM
Todd00's Avatar
I said I don't want a title!
Default Re: Anyone remove the AC in there ITR ??? (SleepyR)
By law, you are allowed to dump 2lbs into the air per year. The R is under that. I just took the little cover off the fill valve, stuck a screwdriver in it and let the thing drain while I did something else.
The lines and condenser are easy to remove if you just pay attention to what's holding them. All-in-all it was a good weight reduction, especially since the main unit is 30 some lbs over and in front of the front tires.
Old Oct 31, 2001 | 05:03 PM
sackdz's Avatar
Default Re: Anyone remove the AC in there ITR ??? (ThePunk)
No, it's not bad. It was bad 15 years ago. Since then strict regulations are in affect, it is not bad for the atmosphere anymore, at least that's wut my organic chem prof told me .
That's why the ****'s so expensive, the old stuff worked great and was cheap, but bad for the ozone.
Old Oct 31, 2001 | 06:17 PM
Jason's Avatar
I'm still thinking about doing it myself...
Chris...I appreciate you sending me the stuff on removing it...looks pretty damn good...I have one ? though...there is one spot where it says to remove something and discard it during the installation (under the glove box, don't remember offhand, but something was there) is that something I need to replace when I remove the A/C? thanks again...appreciate your help
I recommend his advice on getting the paperwork from acura, he was nice enough to send it to me....
Old Oct 31, 2001 | 06:51 PM
nekkedR's Avatar
Default Re: Anyone remove the AC in there ITR ??? (typer98)
if you need to drain the system of freon rather than undoing a connection , cause it makes a pretty big boom(pressure) not to mention the slight oil you'll get all over your paint. take the fill caps of and inside theres a small schrader valve like the ones on your wheels take a skinny screwdriver and put it on the valve, but before you press it down to relive the presser wrap a towel over the valve and the screwdriver that way every thing will be caugt in the towel and not the air, this takes a few minutes longer. do both valves and the system should be drained,but trust me when i say, the stuff tastes horrible when its released fast.
Old Oct 31, 2001 | 07:07 PM
Jason's Avatar
Default Re: Anyone remove the AC in there ITR ??? (nekkedR)
.....and keep your mouth closed when doing it....there, no one should have that problem anymore
Old Oct 31, 2001 | 07:56 PM
Chris's Avatar
Yes you will need to buy that piece...it bridges the gap between the blower and the rest of the vent system. I got it from the guy I sold the AC to (he didnt need it anymore).
As for "sticking a screwdriver in it and lettin it rip"....not a great idea...I tried that too, but even 10 feet away I could not breathe...not to mention that **** sprayed EVERYWHERE, all over the engine and paint.....for $40 take it to Honda or Acura...
Old Oct 31, 2001 | 08:01 PM
Jason's Avatar
cool...thanks again chris...any idea what it costs? roughly?
Old Oct 31, 2001 | 08:16 PM
Chris's Avatar
for some reason the amount of roughly $40 comes to mind.....but I really cant remember, I just know it was unusually high...
Old Oct 31, 2001 | 09:00 PM
Hey u could probably find that piece of an integra in a junk yard that doesnt have AC correct?
Old Oct 31, 2001 | 09:03 PM
Chris's Avatar
yes
Old Oct 31, 2001 | 09:14 PM
thanks for your help chris
I am gonna try to get that paperwork from the dealer when i get a chance
Would u happen to know off a place or site online that has that paperwork
[Modified by NeXtLeVeL_TyPe_R, 6:15 AM 11/1/2001]
[Modified by NeXtLeVeL_TyPe_R, 6:16 AM 11/1/2001]
Kara ej8 civic
20
Aug 10, 2008 06:06 PM
See Are X
Apr 19, 2002 09:49 PM
01-0720
Jan 30, 2002 10:38 PM
