Building a SiR turbo set-up need help.
Old Apr 25, 2004 | 01:15 PM
JSPEC4DR's Avatar
Default Building a SiR turbo set-up need help.
hey guys I got a 1999 Civic SiR and i am planning on boosting it. I want to keep it reliable and only play to push like 8-10psi. I am picking up parts as I have the cash, and got a sweet deal on a used T3 turbo. its a T3 .42 / .48 I am just curious if this is alil too small for my goal, i want to hit 200 at the wheels, with this turbo do it for me, if i only wanna run say 8-10 psi?
Old Apr 25, 2004 | 01:43 PM
TravSi's Avatar
Default Re: Building a SiR turbo set-up need help. (JSPEC4DR)
yea that turbo will make your goals without even losing any breathe....i did 205 whp on my d16 with a t3 on 6psi so on a b16 it would do it no problems what so ever
Old Apr 25, 2004 | 01:45 PM
TurboJesse
Guest
Posts: n/a
Default Re: Building a SiR turbo set-up need help. (TravSi)
it will fall off big time in the upper rpms but if all you want is a budget setup it will still be fun.
Old Apr 25, 2004 | 02:00 PM
TravSi's Avatar
Default Re: Building a SiR turbo set-up need help. (Mpir3)
what trim t3? a 60 trim has the same wheel as a t28 and they dont fall off up top so why would the t3?? u can also upgrade to a .63 turbine which would pull even harder up high, those turbos can make 300 hp...Im talking the 60 trim
Old Apr 25, 2004 | 03:00 PM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TravSi &raquo;</TD></TR><TR><TD CLASS="quote">what trim t3? a 60 trim has the same wheel as a t28 and they dont fall off up top so why would the t3?? u can also upgrade to a .63 turbine which would pull even harder up high, those turbos can make 300 hp...Im talking the 60 trim</TD></TR></TABLE>
he has a .42/.48ar...that turbo will drop off towards redline...i have a .60/.63 on my b16a.
Old Apr 25, 2004 | 06:38 PM
jeremy.'s Avatar
stock b16a right?
Old Apr 25, 2004 | 09:05 PM
nevin's Avatar
b16b?
BOOSTED_JDM_DB8
Feb 13, 2006 10:00 PM
meltman1234
Dec 8, 2005 12:51 PM
wpgcivic
Jul 18, 2004 09:24 PM
M.A.R.C.
Jun 10, 2002 03:23 PM
