Are the 92-95 clusters interchangeable?
Can i switch out parts of the cluster? I have a si cluster...the gas and the temperature doesnt work. Can i buy a cx/dx cluster and switch out the gas/temp into my si cluster?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 »</TD></TR><TR><TD CLASS="quote">Can i switch out parts of the cluster? I have a si cluster...the gas and the temperature doesnt work. Can i buy a cx/dx cluster and switch out the gas/temp into my si cluster?</TD></TR></TABLE>
No.. the DX cluster is different since the temp is one side and fuel is on the other so the wiring on the cluster is different. you will have to get an SI cluster where the temp and fuel are on one unit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing »</TD></TR><TR><TD CLASS="quote">
ah thats right...i think the vx should fit then. Sell me yours for $5
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Green_Hatch »</TD></TR><TR><TD CLASS="quote">if you get a vx cluster, it will work but your rpms will only go to 8grand, and redline will be at 6, so that might bug you.</TD></TR></TABLE>
you can just remove the fuel/temp sensor from the cluster and replace it.. you dont need to swap the whole thing out..
you can just remove the fuel/temp sensor from the cluster and replace it.. you dont need to swap the whole thing out.. </TD></TR></TABLE>
how much do the fuel/temp runs for?
how much do the fuel/temp runs for?</TD></TR></TABLE>
usually people only sell just the whole cluster.. I 'MIGHT" sell you just the fuel / temp if I dont sell my cluster..
unless you can find someone to buy just the cluster housing and the tach.. since my speedometer is semi broken.
unless you can find someone to buy just the cluster housing and the tach.. since my speedometer is semi broken.</TD></TR></TABLE>
yes sell me your cluster fuel/temp. i vill be waiting >:]
unless you can find someone to buy just the cluster housing and the tach.. since my speedometer is semi broken.</TD></TR></TABLE>yes sell me your cluster fuel/temp. i vill be waiting >:]
d16rice
Dec 13, 2005 08:32 PM
jdM eK4 b16B
May 2, 2004 06:55 AM
trooper0641
25
Apr 25, 2004 05:44 PM
