Car pulls hard to the right
Old Apr 25, 2004 | 10:17 AM
CWBETB's Avatar
Default Car pulls hard to the right
Anyone know why my car would be pulling hard to the right when i give it gas? If I lay off the gas it goes straight so I dont think its my allignment. Would a bad Axle cause this? Its like I have tourque steer but I dont remember it being this bad, its even if I give it a slight amount of gas?
Old Apr 25, 2004 | 11:23 AM
roadawg's Avatar
Default Re: Car pulls hard to the right (CWBETB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CWBETB &raquo;</TD></TR><TR><TD CLASS="quote">a bad Axle cause this? </TD></TR></TABLE>
Yes, it happened to me once.....
Old Apr 25, 2004 | 11:28 AM
soviet's Avatar
or you could need a wheel alignment
Old Apr 25, 2004 | 11:33 AM
Jurassic Four's Avatar
From: Where you cant steal it, Maryland, United States
if yours is a ZC, which it said, and you dont have a intermediate shaft installed. It is DEFINATLY tourque steer. On the stock axles, on is about 1/3 longer than the other.
Old Apr 25, 2004 | 11:49 AM
seerxsi's Avatar
yea i have the same problem with my crx, i know i need alignment but its kinda scary bc it pulls really hard to the right , kinda crazy
Old Apr 25, 2004 | 12:27 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
mine does the same thing. im gonna get an alignment and see if it helps
Old Apr 25, 2004 | 04:06 PM
CWBETB's Avatar
Thanks for the input. I am really thinking it may be a axle issue, my trans or axle seems to be whinding alot lately. Also the one boost was leaking a little bit. Anyone else think it may be a bad axle? It seems like only when the gas is applied it pulls, its straight as could be with no gas applied
Old Apr 25, 2004 | 04:07 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
Sounds like you've got too much Torque Steer.
dothacker
Feb 2, 2010 06:45 PM
skateboard_ej8
Oct 7, 2008 11:50 AM
wu tang
Dec 14, 2007 05:31 AM
TurboSI24
Dec 10, 2005 03:41 AM
CWBETB
Apr 28, 2004 05:28 AM
