Slammin' my GSR
Old Oct 31, 2001 | 02:11 PM
5-SpeedFreak's Avatar
New User
Default Slammin' my GSR
I'm looking at suspension products to lower my '01 GSR. I've been told that lowering the car past 1.2" will negatively affect camber, and I will need to constantly rotate my tires.
I've read about camber correctors. How do they work, and do they really fix the problem?
I want to do the suspension the right way the first time!!! Please Help!
Old Oct 31, 2001 | 02:49 PM
Jared's Avatar
Default Re: Slammin' my GSR (passion4healing)
camber correction kits do work, however once lowered so far, if you bring the top of the tire back into spec, you may have to roll the fender lip.
Old Oct 31, 2001 | 02:55 PM
Stephen's Avatar
Default Re: Slammin' my GSR (Jared)
Also as you lower it and correct the camber by tilting the top of the wheel out, you are also pulling out on your driveshafts which could lead to accelerated CV joint wear.
Old Oct 31, 2001 | 05:18 PM
976's Avatar
976
New User
Default Re: Slammin' my GSR (Stephen)
As long as you rotate, balence, and keep suspension toe in alignment, then you won't need a camber kit...
Old Oct 31, 2001 | 07:28 PM
bryant's Avatar
Default Re: Slammin' my GSR (B21A)
i always thought camber was my friend
yeah, just depends on how low you go. if you will need a camber kit or not.
Old Oct 31, 2001 | 08:15 PM
OneThirtyEight's Avatar
Default Re: Slammin' my GSR (CR-X)
I got neuspeed race springs, i now hear a ticking when accelerating. WTF is this? It JUST started a little while ago. Is this my CV joint? or Axle?
Old Oct 31, 2001 | 08:38 PM
John's Avatar
New User
Default Re: Slammin' my GSR (97blackteg)
normally clicking sounds when turning is associated with problems with CV joints...
Old Oct 31, 2001 | 10:26 PM
New User
Default Re: Slammin' my GSR (DunReit)
I believe that I'm going to go with Koni Yellows and Eibach sport springs... Good Choice?? Please let me know! Thanx!
Old Nov 1, 2001 | 09:17 AM
Night Kid's Avatar
New User
sounds good
mrchevez
Aug 17, 2011 12:19 PM
DHutch
Suspension & Brakes
Aug 16, 2006 09:46 PM
peel17
Sep 1, 2005 08:00 AM
MugenHonda
12
Jan 2, 2003 07:39 PM
Wai
Jan 2, 2002 09:08 AM
