4 spring and 6 spring Clutch
I have two b16 oem clutches one has four springs and one have 6 springs
what are the diffrences? The one with four springs is installed and works.
I have a Hydro ls trany, will the 6 spring clutch work?????? Both came on
a jdm b16's.
a jdm b16's.
I wanted to Know if the 6 spring is a cable clutch or what?
I know the other one 4 spring will work but the 6 spring is in
better shape and I would like to use it if possible.
the springs has nothing to do if its cable or hydro, if you have the clutch centering tool see if it fits in it to match the sahft of your tranny and if it does then install it
GEN2 LS
Transmission & Drivetrain
Feb 20, 2014 04:13 AM
