put LSD in today, now NO reverse
Old Apr 25, 2004 | 09:13 AM
JonGP4's Avatar
Default put LSD in today, now NO reverse
ok well i finially got around to putting a LSD in my CRX, and everything went pretty smooth, followed the helms by the nose.. and no problems till i get it all back together and the ****** won't go in reverse, and it grinds into 5th.. i take it all back apart, and everything looks right.. i didn't touch the mainshaft or countershaft, simply removed them together, and took out the differencial??.. so i dun no,.. any tranny guys here?.. i'm fixing to head out and pay someone to fix it.. if worse comes to worse, my local pick and pull has them for 75 bucks, and i'll just pay another 100 to have a professional install it.. but i dun no, my best friend who had done this before was helpping me, and he didn't get it?.. any advise?
Old Apr 25, 2004 | 12:11 PM
JonGP4's Avatar
Default Re: put LSD in today, now NO reverse (JonGP4)
ttt
Old Apr 25, 2004 | 12:21 PM
showtymers619's Avatar
* B A N N E D *
just get it done by the shop.. and watch them and learn from your mistake, its the easiest way to learn is from watching a pro
Old Apr 25, 2004 | 05:31 PM
charjacq's Avatar
New User
Check if you haven't touched anything in the shifting mechanism. Forks, rods, etc.
Old Apr 27, 2004 | 06:28 PM
h22 Eg CoUpE's Avatar
When u put back da mainshaft did u make sure the reverse gear was still there its a small shaft with 1 gear which sits alone n lines up with da mainshaft check dat out
Old May 2, 2004 | 12:20 AM
integramic's Avatar
Having the same problem. But I took everything apart(had the case powercoated and changed some gears).
kixcrx
13
Dec 13, 2006 11:28 PM
speedKILLS
Jul 24, 2006 05:52 PM
JonGP4
16
Apr 27, 2004 10:53 AM
