Turbo Integra vs Stock Camero
Old Apr 25, 2004 | 06:48 AM
highbooster123's Avatar
Default Turbo Integra vs Stock Camero
Im boosting 10 pounds and making a little over 250 hp and I got beat by a stock automatic 98 camero. Can anybody tell me what just happened
Old Apr 25, 2004 | 07:18 AM
nsxmatt's Avatar
Default Re: Turbo Integra vs Stock Camero (highbooster123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highbooster123 &raquo;</TD></TR><TR><TD CLASS="quote">Im boosting 10 pounds and making a little over 250 hp and I got beat by a stock automatic 98 camero. Can anybody tell me what just happened</TD></TR></TABLE>
Your boosting 10 pounds and making a little over 250 hp and I got beat by a stock automatic 98 camero, that's what happened. You also posted in the wrong forum, made a dumb post, and spelled Camaro wrong, so your day is not getting any better
Old Apr 25, 2004 | 07:22 AM
CL9WestCoastin's Avatar
R u sure it was stock or was he squeezing the n2o
Old Apr 25, 2004 | 07:38 AM
Dov's Avatar
Dov
Default Re: Turbo Integra vs Stock Camero (loketran)
Wow you need help
2001 GSR Stock everything Bolt on drag kit on 6psi
http://www.jenracing.com/images/jen1279.wmv
Old Apr 25, 2004 | 08:46 AM
DIRep972's Avatar
Smarter than you
maybe you need to learn to drive?
Old Apr 25, 2004 | 04:53 PM
quik sol's Avatar
3 things:
1. Bad turbo install and has leaks.
2. Not a stock Camaro.
3. You need to learn how to drive.
Old Apr 25, 2004 | 05:15 PM
b16ahybrid's Avatar
Default Re: Turbo Integra vs Stock Camero (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">maybe you need to learn to drive?</TD></TR></TABLE>
I'm going with that one.
Just cause your making 250 hp doesn't mean that you can drive. Anybody can make 250 hp.
Just because your set-up "should in theory" run 13's doesn't meant that you will.
Hell I remember my first day at the track, i was nervous/excited running 10psi on my b16 I could only manage a low 15 sec ET.....doesn't seem rite for 10psi on a b16, but hat was because I could drive worth ****......fast forward to today........see sig @ 12psi.
Old Apr 25, 2004 | 05:40 PM
tegmech's Avatar
learn to drive, you should have taken that! that is if everything is running right.
Old Apr 25, 2004 | 06:28 PM
quikB18B's Avatar
Default Re: (tegmech)
Was this from a dead stop? If it was never underestimate an Auto ls1, traction owns you
However if this race was not at a dead stop then
you either
1) cant drive
2) something is wrong with your car
3) or the guy lied to you, trust me domestic guys are notorious for failing to tel you all thier mods
Old Apr 25, 2004 | 06:52 PM
b16ahybrid's Avatar
Default Re: (quikB18B)
Originally Posted by quikB18B trust me domestic guys are notorious for failing to tel you all thier mods [img
https://honda-tech.com/forums/images/smilies/emwink.gif[/img]
Thats because they don't want to lose to an import.....
Old Apr 25, 2004 | 11:38 PM
xplanetearth420x's Avatar
Default Re: (b16ahybrid)
few things
bad turbo install
camaro wasnt stop
it might need to be tuned
you suck at driving
Old Apr 26, 2004 | 02:02 AM
TRAY's Avatar
you broke the welds on your intake
Old Apr 26, 2004 | 02:22 PM
Default Re: Turbo Integra vs Stock Camero (TrayDay2K1)
talked to the guy again hes all stock and told me that LS1's will take any ricer. He was a real dick. we went from a 20 punch and it was'nt my driving he just up and walked away from me.
Old Apr 26, 2004 | 02:58 PM
sleepy96's Avatar
You just suck at driving, A boosted integra Should stomp a Stock Camero any day
Old Apr 26, 2004 | 03:06 PM
usdm420's Avatar
816d16 owes me money!
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: Turbo Integra vs Stock Camero (87sleeper)
you should at leasat give him a run for his $$$ especially from a rollin start
Old Apr 26, 2004 | 04:33 PM
rice a roni's Avatar
Default Re: Turbo Integra vs Stock Camero (usdm420)
ummm different story but i raced my friends 89 camaro i-rock...(305 small block) and wasted him by 2 cars...but thats when i let him catch traction before i launched..camaro was stock...i was too except for the 5zigen catback.
Old Apr 27, 2004 | 05:11 PM
DIRep972's Avatar
Smarter than you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highbooster123 &raquo;</TD></TR><TR><TD CLASS="quote">talked to the guy again hes all stock and told me that LS1's will take any ricer. He was a real dick. we went from a 20 punch and it was'nt my driving he just up and walked away from me.</TD></TR></TABLE>
20 punch you should start in 1st gear.. If you started in 2nd gear from a 20 roll you would bog(could be your first problem).. If you started in 1st gear: the first question I ask you is what kinda tires do you have?? anything but a drag radial will spin from a 20 roll.. Tires spinning on your car and not the LS1 hes going to walk away from you.. Say your on radials; you are a bad driver and you react late, shift early before redline, and shift slowly... you lost!!! say thats not the case and he pulled you hard anyways and you didn't bog/spin.... Hes either lying about his mods, and is not stock, or something is wrong w/ your set up.. From a roll there are not too many variables.. A stock LS1 goes 103-105 in the 1/4 depending on the day it was built, the driver, and the model type(effects wieght).. A 250whp Integra should do about the same.. Again, from a roll w/ next to no variables effecting the race the car w/ the higher trap speed wins.. A 105 car to a 103 will edge out in front off a 20 roll @ about 60mph to one car and continue to put another car to 100. How bad did he beat you?
Old Apr 27, 2004 | 08:49 PM
Tushner's Avatar
Default Re: Turbo Integra vs Stock Camero (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">
Your boosting 10 pounds and making a little over 250 hp and I got beat by a stock automatic 98 camero, that's what happened. You also posted in the wrong forum, made a dumb post, and spelled Camaro wrong, so your day is not getting any better </TD></TR></TABLE>
That was some rapid ownage...
Endemic
Sep 18, 2007 12:03 AM
!EDWARDS!
Jun 2, 2004 03:32 PM
PreludeK
Jun 8, 2003 06:23 PM
SNEAKERACING
May 23, 2002 05:49 PM
