Upper radiator hose for del sol s w/ b18c1
do you know if anyone makes a hose that is reduced to fit the del sol radiator? I keep damaging my hoses because I have to tighten the radiator side too much because the hose is so much bigger than the inlet for the radiator.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsolrob »</TD></TR><TR><TD CLASS="quote">do you know if anyone makes a hose that is reduced to fit the del sol radiator? I keep damaging my hoses because I have to tighten the radiator side too much because the hose is so much bigger than the inlet for the radiator.</TD></TR></TABLE>
cut a piece of an old radiator hose off, and sandwhich it between the clamp and the new hose. it'll reduce some of the pinching effect of using a large hose with a small outlet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch »</TD></TR><TR><TD CLASS="quote">buy a dual core radiator... your motor will be much happier with you.</TD></TR></TABLE>
i have a dual core radiator, but the inlet/outlets are still the same size as my stock CX
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsolrob »</TD></TR><TR><TD CLASS="quote">what radiator will fit and also have the right size inlet?</TD></TR></TABLE>
integra will have the correct size. i can only assume that the dual core for a delsol doch vtec will have the correct size also. fluidyne makes a narrow dual core with larger outlets (teg size) also.
Shoot0
Nov 20, 2010 04:28 PM
Mr. JDM-GSR
Feb 9, 2006 05:30 AM
SiRcyrusEH2
May 18, 2004 04:44 PM
