is the bov open at idle. mine sure is. but in boost it closes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xrunner86x »</TD></TR><TR><TD CLASS="quote">blow off should not be open in vacuum. </TD></TR></TABLE>
how do you expect it to release the excess pressure then? Last time I checked, when you let off the throttle under boost, you go into vacuum.
Mine was always open, but only slightly, and it created a whistling sound every time the rpm's dropped to around idle.
