Installed Air/Fuel Gauge.. getting nothing from white wire..
Old Apr 24, 2004 | 09:13 PM
GSlowR's Avatar
Default Installed Air/Fuel Gauge.. getting nothing from white wire..
is there a possibility that my o2 sensor went bad.. I noticed a while back that my o2 sensor wasn't even connected..i never saw a check engine light either.. maybe the bulb on my check engine light is out? But regardless my gauge isn't reading anything from the white wire.. what do you guys think?
Old Apr 25, 2004 | 07:49 AM
GSlowR's Avatar
Default Re: Installed Air/Fuel Gauge.. getting nothing from white wire.. (GSlowR)
bump.. com'on guys someone's got to have an answer
Old Apr 25, 2004 | 09:40 PM
EF_LSVtec's Avatar
what kind O2 sensor do you have, 1 or 4 wire heated? stock ecu?
Old Apr 26, 2004 | 01:42 PM
GSlowR's Avatar
Default Re: Installed Air/Fuel Gauge.. getting nothing from white wire.. (EF_LSVtec)
4 wire.. has 2 black 1 white and 1 green.. it's a stock o2 sensor.. and I have a p28 chipped to mugen specs..
Old Apr 26, 2004 | 02:03 PM
92RED Hatch's Avatar
you can check to see if your bulb is working on your check engine light by just turning the key all the way foward like you were about to start your car and the car should do its usual beep..beep..beep..and also your check engine light should light up until you start your car then it goes off unless there is somethin wrong
Old Apr 26, 2004 | 02:33 PM
GSlowR's Avatar
Default Re: Installed Air/Fuel Gauge.. getting nothing from white wire.. (92RED Hatch)
good idea.. never thought about that =P
Old Apr 26, 2004 | 05:41 PM
GSlowR's Avatar
bump for the night
Old Apr 27, 2004 | 02:42 AM
GSlowR's Avatar
bump.. i guess nobody knows??
Old Apr 27, 2004 | 07:22 AM
EF_LSVtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSlowR &raquo;</TD></TR><TR><TD CLASS="quote">4 wire.. has 2 black 1 white and 1 green.. it's a stock o2 sensor.. and I have a p28 chipped to mugen specs..</TD></TR></TABLE>
I'm guessing that the chipped Mugen spec ECU has disabled O2 sensor along with (speed/rev limiter, knock sensor etc)...If you can get a hold (borrow) a stock P28 hopefully it'll give you a code or something. Not sure how to test an O2 sensor with a tester or I guess you can also borrow another O2.
Old Apr 27, 2004 | 09:57 AM
GSlowR's Avatar
hrmm well i guess the only true way of getting it fixed is to get it dyno tuned now.. i also think i need to get my valves adjusted..
Old Apr 27, 2004 | 11:11 AM
Qfactor's Avatar
most likely a dead O2 sensor and or fualty wiring, bad gauge. try it on a different car.
Old Apr 27, 2004 | 02:07 PM
GSlowR's Avatar
Default Re: Installed Air/Fuel Gauge.. getting nothing from white wire.. (Qfactor)
ok well now it's somewhat working.. might be working fully but I don't know..
while accellerating it stays at rich.. while idling it's stoich.. but when i let off the gas it seems to go stoich-&gt;lean.. i thought the gauge was supposed to be bouncing back and forth.. I had to adjust my fuel pressure regulator to 30psi and my v-afc is taking making 10% off.. but after doing that i swear it sounds like a lot of valve pinging..especially when i shift gears.. any idea guys?? the compression should be 12.6:1 ctr pistons, skunk2 valvetrain(stage 1 cams) and rc 310cc injectors..
Old Apr 27, 2004 | 04:54 PM
Qfactor's Avatar
[QUOTE=GSlowR]ok well now it's somewhat working.. might be working fully but I don't know..
QUOTE]
yeah O2 sensors get lazy after time..
Old Apr 27, 2004 | 08:39 PM
GSlowR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Qfactor &raquo;</TD></TR><TR><TD CLASS="quote">[QUOTE=GSlowR]ok well now it's somewhat working.. might be working fully but I don't know..
QUOTE]
yeah O2 sensors get lazy after time..</TD></TR></TABLE>
welp I think i got it working.. my roommate said that it was supposed to run like that but said it still looks a lil bit strange.. good enough for me.. i just gotta get it on the dyno
Old Apr 28, 2004 | 12:48 PM
GSlowR's Avatar
also one last thing.. i noticed on autometers website that they specify to tap into the wire above the connector.. is it really that necessary? as i didn't know and tapped in below the connector
Old May 25, 2004 | 05:59 PM
sm00thk0zz's Avatar
Default Re: (GSlowR)
Says to connect after the connector because the wire leading to the connector could be shelded wire, where as the wireing harness isn't.
SQ is the SQUAD
Engine Management and Tuning
May 9, 2010 07:17 PM
MniMeHatch89
May 25, 2006 01:31 PM
WAX
Jan 5, 2005 03:55 PM
Kermit EK
Feb 27, 2003 11:49 PM
1999PreludeSH
Mar 26, 2002 06:53 PM
